Everything works but every few weeks I need to grant access via web of some users or renew appkeys for others
    • all versions including 32
    • ubuntu 24.04
    • replace apache
    • yes apache
    • 8.3
    • been slowly getting worse
    • years
    • bare
    • no
  • Summary of the issue you are facing:
Every few weeks all the users logins fail and a web user need to grant access again and appkeys need to be regenerated. this seems to be getting more frequent
Steps to replicate it (hint: details matter!):slight_smile:
cant replicate it just happens. i go see a 404 for the login url in apache, which if i have read right means keys expired. Ive flushed the relivant caches passwords
PASTE HERE
PASTE
"POST /index.php/login/v2/poll HTTP/1.1" 404 4108 "-" "Mozilla/5.0 (Windows) mirall/4.0.5
<IfModule mod_ssl.c>
<VirtualHost xxx.xxx.xxx.xxx:443>
  DocumentRoot /path/nextcloud/
  ServerName  url
  ErrorLog ${APACHE_LOG_DIR}/HTTPSerror/url.error.log
  CustomLog ${APACHE_LOG_DIR}/HTTPSaccess/url.access.log combined
  <Directory /path/nextcloud/>
    LimitRequestBody 0
    Require all granted
    AllowOverride All
    Options FollowSymLinks MultiViews
    <IfModule mod_dav.c>
      Dav off
    </IfModule>
         SetEnv HOME /path/nextcloud
        SetEnv HTTP_HOME /path/nextcloud
        Satisfy Any
  </Directory>
        Header set X-Content-Type-Options: nosniff
        Header set X-XSS-Protection: 1
        Header set X-Robots-Tag: none
        Header always unset X-Frame-Options
        Header set X-Frame-Options "SAMEORIGIN"
        Header unset ETag
        FileETag None
        Header always set X-Content-Type-Options nosniff
        Header always set Strict-Transport-Security "max-age=63072000; includeSubdomains; preload"
SSLCertificateFile /etc/letsencrypt/live/url/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/url/privkey.pem
</VirtualHost>
</IfModule>
  'debug' => false,
  'instanceid' => 'id',
  'passwordsalt' => 'password',
  'secret' => 'secret',
    0 => 'xxx.xxx.xxx.xxx',
    1 => 'url',
  'overwrite.cli.url' => 'http://url',
  'datadirectory' => '/path/nextcloud/data',
  'version' => '32.0.6.1',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => 'username',
  'dbpassword' => 'password',
  'default_phone_region' => 'GB',
  'theme' => '',
  'loglevel' => 2,
  'twofactor_enforced' => 'false',
Has no one seen this before ??? Did i miss any details ?
Is this for regular user passwords? Or just app passwords?
My app passwords do not expire, not sure if there is a way to make them expire, but you haven’t voluntarily turned it on?
There is, I think, a routine to remove app passwords if they haven’t been used for a long time (range of months).
From your config, there is no caching used at all. This put a significant higher load on the database. I don’t really see how this invalidates passwords. Or it just fails, when there is a large load and you saturate the database? But timeouts or connection limits should show in the logs.
Its both, password and app passwords. . The app passwords are used regularly every 20 mins from a nextcloudcmd sync i use for backsups. I’ve reduced the cron.php from every 5 mins to every 15 as a guess. The system is never under heavy load as its just used by a few people
Bruteforce protection?
set to allow the devices on the internal network to bypass brute force protection, and things like the app passwords are only ever accessed internally
by any chance are there entries in the NC-log that would hint into that direction?
any setup-messages left to solve?
yeah, this one doesn’t look like apache randomly breaking.
/index.php/login/v2/poll returning 404 is usually “login-flow token expired/not found”, not cert keys dying.
i’d check this in order:
  • did secret in config.php ever change? (if yes, old app passwords/tokens can break)
  • check token retention:
    • php occ config:system:get token_auth_token_retention
    • php occ config:system:get token_auth_wipe_token_retention
  • compare tokens before/after an incident:
    • php occ user:auth-tokens:list --output=json_pretty
  • check nextcloud.log at failure time for token invalidation/cleanup lines
also two quick things:
  • your user-agent shows mirall/4.0.5 (very old desktop client) → update clients
  • set overwrite.cli.url to https://… (yours is http://…)
if you post raw nextcloud.log lines from first failure window, this should be diagnosable fast.
