Errors not visible. "See below for errors" - but there are no errors (Linux Client)
    • 30.0.15 (nextcloudpi)
    • Ubuntu 25.04
    • curl -head only shows “Apache” not sure where else to find it.
    • ? I don’t think I’m using a reverse proxy. How could I find out?
    • 8.3.17
    • no
    • from the beginning of installing this client
    • ncp
    • I don't know
The desktop client says “Some files cannot be synced. See below for errors. But there are no errors.
I know this is because my KDE system does not always automount the drive with nextcloud data on it, even though I have configured it to. However my issue with the nextcloud desktop client is that “See below for errors” is a lie! There are no errors below. (Fig. 1). Even if you scroll all the way to the bottom (not pictured).
If I hover over the systray icon, it says “setup error” which is the only clue that the desktop client can’t find the data. (Fig. 2).
Does anybody else have this problem or a solution to nextcloud errors not being visible?
Fig. 1. Nextcloud dialog with message “Some files couldn’t be synced! / See below for errors” but no errors visible.
nc-setup-error-Screenshot_20251013_140517-2
Fig. 2. Nextcloud Systray icon with red circle and !, and a tooltip when you hover over it that says, “/media/user/mountpoint: Setup error.”
  1. Install Nextcloud Client (download and run the AppImage), select an automounted drive as the local storage directory
  2. Reboot computer. (make sure KDE does not automount the drive.)
  3. Problem exists: Systray icon shows a red circle with a !, and you see the “See below for errors” message without any error messages.
  4. “Fix” the error by mounting the NC data location, then pausing and restarting sync.
Available if requested.
N/A
N/A
N/A
N/A
Dis you scroll down the list?
@Mornsgrans thank you for your help.
Yes I did scroll down the list. Sorry if it got lost in the text.
