no matter what i do, some errors simple don’t go away.
I still get the following:
There are some warnings regarding your setup.
Your web server is not properly set up to resolve "/ocm-provider/". This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in ".htaccess" for Apache or the provided one in the documentation for Nginx. On Nginx those are typically the lines starting with "location ~" that need an update. For more details see the documentation ↗.
Your web server is not properly set up to resolve `.well-known` URLs, failed on: `/.well-known/webfinger` For more details see the documentation ↗.
But my .htaccess file shows:
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
<IfModule mod_lsapi.c>
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
# Avoid doubled headers by unsetting headers in "onsuccess" table,
# then add headers to "always" table: https://github.com/nextcloud/server/pull/19002
Header onsuccess unset Referrer-Policy
Header always set Referrer-Policy "no-referrer"
Header onsuccess unset X-Content-Type-Options
Header always set X-Content-Type-Options "nosniff"
Header onsuccess unset X-Frame-Options
Header always set X-Frame-Options "SAMEORIGIN"
Header onsuccess unset X-Permitted-Cross-Domain-Policies
Header always set X-Permitted-Cross-Domain-Policies "none"
Header onsuccess unset X-Robots-Tag
Header always set X-Robots-Tag "noindex, nofollow"
Header onsuccess unset X-XSS-Protection
Header always set X-XSS-Protection "1; mode=block"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for static resources
<FilesMatch "\.(css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite)$">
<If "%{QUERY_STRING} =~ /(^|&)v=/">
Header set Cache-Control "max-age=15778463, immutable"
</If>
<Else>
Header set Cache-Control "max-age=15778463"
</Else>
</FilesMatch>
# Let browsers cache WOFF files for a week
<FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
</FilesMatch>
</IfModule>
<IfModule mod_php.c>
php_value mbstring.func_overload 0
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddType application/wasm wasm
AddEncoding gzip svgz
# Serve ESM javascript files (.mjs) with correct mime type
AddType text/javascript js mjs
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{HTTP_USER_AGENT} DavClnt
RewriteRule ^$ /remote.php/webdav/ [L,R=302]
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteRule ^\.well-known/(?!acme-challenge|pki-validation) /index.php [QSA,L]
RewriteRule ^ocm-provider/?$ index.php [QSA,L]
RewriteRule ^/ocm-provider/?$ /index.php [QSA,L]
RewriteRule ^(?:\.(?!well-known)|autotest|occ|issue|indie|db_|console).* - [R=404,L]
RewriteRule ^\.well-known/webfinger /index.php/.well-known/webfinger [R=301,L]
RewriteRule ^\.well-known/nodeinfo /index.php/.well-known/nodeinfo [R=301,L]
</IfModule>
# Clients like xDavv5 on Android, or Cyberduck, use chunked requests.
# When FastCGI or FPM is used with apache, requests arrive to Nextcloud without any content.
# This leads to the creation of empty files.
# The following directive will force the problematic requests to be buffered before being forwarded to Nextcloud.
# This way, the "Transfer-Encoding" header is removed, the "Content-Length" header is set, and the request content is proxied to Nextcloud.
# Here are more information about the issue:
# - https://docs.cyberduck.io/mountainduck/issues/fastcgi/
# - https://docs.nextcloud.com/server/latest/admin_manual/issues/general_troubleshooting.html#troubleshooting-webdav
SetEnvIf Transfer-Encoding "chunked" proxy-sendcl=1
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /index.php/error/403
ErrorDocument 404 /index.php/error/404
My nextcloud root is a /var/www/nextcloud and bseside these errors, no others.
Any hint of what is wrong as i can’t find it?
Thx in advance!
