I Installed a Nexcloud Server on my System to have a outside Connection to my files I make the sync with cloud_sync from a synology System RS214 but I have allways Errors on my nextcloud system. The synology system have a slow Inet, the nextcloud system is much better ;-).
In my Nextcloud log I found this:
example
longer
example
here
Nextcloud version (eg, 13.0.2): 13.2.1
Operating system and version (eg, CenTos 7.0e): CentOS 7.5
PHP version (eg, 7.1): 7.2
Sabre\DAV\Exception\BadRequest: expected filesize 17408 got 0
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1130: OCA\DAV\Connector\Sabre\File->put(Resource id #6)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 513: Sabre\DAV\Server->updateFile('Daten/Arbeit/BA...', Resource id #6, NULL)
[internal function] Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method PUT', Array)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/html/nextcloud/apps/dav/appinfo/v1/webdav.php - line 80: Sabre\DAV\Server->exec()
/var/www/html/nextcloud/remote.php - line 164: require_once('/var/www/html/n...')
{main} Sabre\DAV\Exception\BadRequest: expected filesize 17408 got 0
{main}
Can any help to found this mystake please
'instanceid' => 'xxxxxxxxxxxxxx',
'passwordsalt' => 'yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy',
'secret' => 'yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy',
0 => 'cloud.xxxxxxxx.yy',
'datadirectory' => '/srv/nextcloud/data',
'overwrite.cli.url' => 'https://cloud.xxxxxxx.at/nextcloud',
'version' => '13.0.2.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextuser',
'dbpassword' => 'XXXXXXXXXXXXX',
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'theme' => '',
'loglevel' => 2,
'logtimezone' => 'Europe/Vienna',
'log_rotate_size' => 104857600,
'mail_from_address' => 'gjn+nextcloud',
'mail_smtpmode' => 'php',
'mail_domain' => 'xxxxxxxxxxx.at',
'mail_smtpsecure' => 'tls',
'mail_smtphost' => 'mx03.xxxxxxxxxxx.at',
'mail_smtpport' => '587',
'mail_smtpauth' => 1,
'mail_smtpname' => 'gjn@xxxxxxxxxxx.at',
'mail_smtppassword' => 'XXXXXXXXXXXXXX',
PASTE HERE
