ErrorCall to undefined method OC\DB\QueryBuilder\QueryBuilder::execute()
    • Nextcloud Hub 26 Winter (33.0.0)
    • linuxserver/nextcloud:latest
    • nginx
    • nginx
    • from quite some time
    • after some update
    • Docker linuxserver/nextcloud:latest
In Overview I found “942 errors in the logs since 1. März 2026, 16:25:41”. After checking logs I see a lot of errors like
Error no app in context ErrorCall to undefined method OC\DB\QueryBuilder\QueryBuilder::execute() 08.03.2026, 16:26:27
Error webdav ErrorCall to undefined method OC\DB\QueryBuilder\QueryBuilder::execute() 08.03.2026, 16:26:27
  1. Open Overview
  2. Find “942 errors in the logs since 1. März 2026, 16:25:41”
  3. Check logs
Error
	no app in context
Error
	webdav
Error
	no app in context
	08.03.2026, 16:26:26
Error
	webdav
Error
	no app in context
	08.03.2026, 16:26:16
Error
	webdav
Error
	no app in context
	08.03.2026, 16:26:09
Error
	webdav
Error
	no app in context
	08.03.2026, 16:26:05
Error
	webdav
PASTE
PASTE HERE
            "cloud.example.com",
            "192.168.178.2:8088",
            "cloud.example.com:8088"
        "dbtype": "sqlite3",
        "version": "33.0.0.16",
        "overwrite.cli.url": "https:\/\/cloud.example.com",
        "overwriteprotocol": "https",
        "overwritehost": "cloud.example.com,
        "twofactor_enforced": "false",
        "bulkupload.enabled": false,
        "twofactor_enforced_groups": [],
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpport": "465",
        "mail_smtpauthtype": "PLAIN",
        "theme": "",
        "loglevel": 1,
        "filelocking.enabled": "true",
        "memcache.locking": "\\OC\\Memcache\\APCu",
        "upgrade.disable-web": true,
        "mail_smtpsecure": "ssl",
        "tempdirectory": "\/data\/temp",
        "enabledPreviewProviders": [
            "OC\\Preview\\BMP",
            "OC\\Preview\\GIF",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\Krita",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\MP3",
            "OC\\Preview\\OpenDocument",
            "OC\\Preview\\PNG",
            "OC\\Preview\\TXT",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\MP4",
            "OC\\Preview\\Movie",
            "OC\\Preview\\Image",
            "OC\\Preview\\TIFF",
            "OC\\Preview\\TF"
        "memories.exiftool": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "memories.index.mode": "3",
        "memories.index.path": "\/Photos",
        "memories.vod.disable": false,
        "memories.vod.vaapi.low_power": true,
        "app_install_overwrite": [
            "files_texteditor",
            "snappymail",
            "maps"
        "memories.video_default_quality": "-2",
        "memories.vod.vaapi": true,
        "memories.vod.external": true,
        "memories.vod.connect": "go-vod:47788",
        "files.chunked_upload.max_size": 150000000,
        "config_preset": 2
  • activity: 6.0.0-dev.0
  • admin_audit: 1.23.0
  • app_api: 33.0.0
  • assistant: 3.3.0
  • bruteforcesettings: 6.0.0-dev.0
  • circles: 33.0.0
  • comments: 1.23.0
  • contactsinteraction: 1.14.1
  • dashboard: 7.13.0
  • dav: 1.36.0
  • federation: 1.23.0
  • files: 2.5.0
  • files_automatedtagging: 4.0.0
  • files_downloadlimit: 5.1.0-dev.0
  • files_external: 1.25.1
  • files_pdfviewer: 6.0.0-dev.0
  • files_reminders: 1.6.0
  • files_sharing: 1.25.2
  • files_trashbin: 1.23.0
  • files_versions: 1.26.0
  • firstrunwizard: 6.0.0-dev.0
  • integration_dropbox: 4.1.0
  • integration_openai: 4.3.0
  • integration_paperless: 1.0.11
  • logreader: 6.0.0
  • mail: 5.7.2
  • maps: 1.6.0
  • notifications: 6.0.0
  • oauth2: 1.21.0
  • oidc: 1.16.2
  • password_policy: 5.0.0-dev.0
  • photos: 6.0.0-dev.0
  • previewgenerator: 5.13.0
  • privacy: 5.0.0-dev.0
  • profile: 1.2.0
  • provisioning_api: 1.23.0
  • recommendations: 6.0.0-dev.0
  • related_resources: 4.0.0-dev.0
  • serverinfo: 5.0.0-dev.0
  • settings: 1.16.0
  • sharebymail: 1.23.0
  • snappymail: 2.38.2
  • support: 5.0.0
  • survey_client: 5.0.0-dev.0
  • suspicious_login: 11.0.0-dev.0
  • systemtags: 1.23.0
  • text: 7.0.0-dev.3
  • theming: 2.8.0
  • twofactor_totp: 15.0.0-dev.0
  • updatenotification: 1.23.0
  • user_status: 1.13.0
  • viewer: 6.0.0-dev.0
  • weather_status: 1.13.0
  • webhook_listeners: 1.5.0
  • workflowengine: 2.15.0
  • encryption: 2.21.0
  • guests: 4.6.0 (installed 4.6.0)
  • memories: 7.8.2 (installed 7.8.2)
  • notes: 4.13.0 (installed 4.13.0)
  • twofactor_webauthn: 2.6.0 (installed 2.6.0)
  • user_ldap: 1.24.0
If you check the full (raw) log entry you’ll likely see maps referenced. You have it force enabled so compatibility checks are bypassed at update/upgrade time.
This has come up on the forum previously; probably would have come up in a search. :wink:
