I’m following the steps in: HowTo: Ubuntu + Docker + Nextcloud + Talk + Collabora
I’m at the part where I added smb support, 5.4. Prior to this everything is fine, but trying to rebuild a custom image I get the following error after updating my dockerfile:
$ docker-compose up --build (or $ docker-compose build --pull)
Building nextcloud
Traceback (most recent call last):
File “bin/docker-compose”, line 3, in
File “compose/cli/main.py”, line 67, in main
File “compose/cli/main.py”, line 126, in perform_command
File “compose/cli/main.py”, line 1070, in up
File “compose/cli/main.py”, line 1066, in up
File “compose/project.py”, line 615, in up
File “compose/service.py”, line 346, in ensure_image_exists
File “compose/service.py”, line 1125, in build
File “docker/api/build.py”, line 160, in build
File “docker/utils/build.py”, line 30, in tar
File “docker/utils/build.py”, line 49, in exclude_paths
File “docker/utils/build.py”, line 214, in rec_walk
File “docker/utils/build.py”, line 184, in rec_walk
PermissionError: [Errno 13] Permission denied: ‘/home/username/nextcloud/mariadb/nextcloud’
[29500] Failed to execute script docker-compose
Currently mariadb folder owner: systemd Core Dumper, Group: root and /mariadb/nextcloud/ is unreadable, and owner/group: systemd Core Dumper. Every single item in /mariadb directory has a red x icon on it.
Any thoughts on what I need to change? I haven’t changed permissions on mariadb yet, I tried earlier setting it to www-data but it didn’t change anything, so I deleted all the docker-compose and docker images and the data html mariadb folders in /nextcloud and rebuilt.
Here is my docker-compose.yml (there is proper indentation in my actual file):
version: ‘3.7’
networks:
nextcloud:services:
nextcloud:
image: nextcloud:custom_smb
build: .
container_name: nextcloud
networks:
- nextcloud
ports:
- “127.0.0.1:8080:80”
volumes:
- ${NEXTCLOUD_ROOT}/html:/var/www/html
- ${NEXTCLOUD_ROOT}/data:/srv/nextcloud/data
extra_hosts:
- “${NEXTCLOUD_FQDN}:${NEXTCLOUD_IPADDRESS}”
- “${COLLABORA_FQDN}:${NEXTCLOUD_IPADDRESS}”
depends_on:
- mariadb
- redis
environment:
- NEXTCLOUD_TRUSTED_DOMAINS=’${NEXTCLOUD_FQDN}’
- NEXTCLOUD_DATA_DIR=/srv/nextcloud/data
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
- MYSQL_PASSWORD=${MYSQL_PASSWORD}
- MYSQL_HOST=nextcloud-mariadb
- REDIS_HOST=nextcloud-redis
restart: unless-stoppedmariadb:
image: mariadb
container_name: nextcloud-mariadb
volumes:
- ${NEXTCLOUD_ROOT}/mariadb:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}
networks:
- nextcloudredis:
image: redis
container_name: nextcloud-redis
networks:
- nextcloud
restart: unless-stoppedcoturn:
image: instrumentisto/coturn
container_name: nextcloud-coturn
ports:
- “3478:3478/tcp”
- “3478:3478/udp”
networks:
- nextcloud
command:
- -n
- --log-file=stdout
- --min-port=49160
- --max-port=49200
- --realm=${NEXTCLOUD_FQDN}
- --use-auth-secret
- --static-auth-secret=${COTURN_SECRET}collabora:
image: collabora/code
container_name: nextcloud-collabora
networks:
- nextcloud
ports:
- “127.0.0.1:9980:9980”
extra_hosts:
environment:
- ‘domain=${NEXTCLOUD_FQDN}’
- ‘dictionaries=en’
cap_add:
- MKNOD
tty: true
