I am having issues manually uploading files to Nextcloud. I have the docker AIO and have used rsync to copy about a TB of data from an external hard drive I have to Nextcloud. The copy went good, I saw online and learned from another article that I need to run this command to allow the files to show up… sudo docker exec --user www-data -it nextcloud-aio-nextcloud php occ files:scan --all. I ran that command but it’s giving me the following error…
Exception during scan: An exception occurred while executing a query: SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
#0 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1780): Doctrine\DBAL\Driver\API\PostgreSQL\ExceptionConverter->convert(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#1 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1719): Doctrine\DBAL\Connection->handleDriverException(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#2 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1173): Doctrine\DBAL\Connection->convertExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDO\Exception), 'UPDATE "oc_file...', Array, Array)
#3 /var/www/html/lib/private/DB/Connection.php(294): Doctrine\DBAL\Connection->executeStatement('UPDATE "oc_file...', Array, Array)
#4 /var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(354): OC\DB\Connection->executeStatement('UPDATE "oc_file...', Array, Array)
#5 /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php(281): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/html/lib/private/Files/Cache/Cache.php(382): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/html/lib/private/Files/Cache/Scanner.php(403): OC\Files\Cache\Cache->update(161764, Array)
#8 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 161764, true)
#9 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 161752, true)
#10 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 161722, true)
#11 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 157429, true)
#12 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 91400, true)
#13 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups/L...', true, 3, 65007, true)
#14 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files/Backups', true, 3, 57019, true)
#15 /var/www/html/lib/private/Files/Cache/Scanner.php(394): OC\Files\Cache\Scanner->scanChildren('files', true, 3, 44111, true)
#16 /var/www/html/lib/private/Files/Cache/Scanner.php(342): OC\Files\Cache\Scanner->scanChildren('', true, 3, 3957, true, Array)
#17 /var/www/html/lib/private/Files/Utils/Scanner.php(256): OC\Files\Cache\Scanner->scan('', true, 3)
#18 /var/www/html/apps/files/lib/Command/Scan.php(161): OC\Files\Utils\Scanner->scan('/gclever', true, NULL)
#19 /var/www/html/apps/files/lib/Command/Scan.php(217): OCA\Files\Command\Scan->scanFiles('gclever', '/gclever', false, Object(Symfony\Component\Console\Output\ConsoleOutput), false, true, false)
#20 /var/www/html/3rdparty/symfony/console/Command/Command.php(255): OCA\Files\Command\Scan->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#21 /var/www/html/core/Command/Base.php(177): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#22 /var/www/html/3rdparty/symfony/console/Application.php(1009): OC\Core\Command\Base->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#23 /var/www/html/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand(Object(OCA\Files\Command\Scan), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#24 /var/www/html/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#25 /var/www/html/lib/private/Console/Application.php(213): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#26 /var/www/html/console.php(100): OC\Console\Application->run()
#27 /var/www/html/occ(11): require_once('/var/www/html/c...')
#28 {main}
I checked my Nextcloud site and it’s showing some of the files but not nearly all of them. It has some blank folders which should have files in them. Any idea on what the issue is?
