Error while running cron.php on hosted installation
On my hosted Nextclout installation we face this error while running cron.php out of a cron job on the hostes server:
www/mydomain.org/ewc/cron.php: cannot open ?php: No such file or directory
www/mydomain.org/ewc/cron.php: 3: Syntax error: word unexpected (expecting ")")
Any ideas? What did I wrong?
You called the script directly and your shell is trying to execute it instead of pasing it to php executing it.
so instead of
you should run
php -f www/mydomain.org/ewc/cron.php
h.t.h.
Much and good luck,
ernolf
Great! Works! Solved!
MNY TNX
