Has anyone seen this before?
Error while running background job (Doctrine\DBAL\Exception\SyntaxErrorException): An exception occurred while executing ‘DELETE FROM oc_activity_mq
WHERE amq_timestamp
<= ? AND amq_affecteduser
IN ()’ with params [1483382700]: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘)’ at line 1
