Bug description
Uploading files larger than 10MB in shared folders with s3 compatible
This error appears again forcing me to acquire a commercial webdav client and abandon this product definitively, I can not upload files larger than 10MB in shared folders when my primary storage is s3, if I try to upload a file to an external drive where I have shared a folder with XFS format it works fine.
I have tried with the latest client version
Steps to reproduce
- I copy the file to a folder that has been shared with me, the folder is part of my primary storage.
- The client returns the error “Uploadpartycopy is not implemented for multipart uploads”.
- If I copy this file outside the shared folder, it copies correctly.
I have tried adding ‘useMultipartCopy’ => false, in the configuration but the problem persists.
Expected behavior
That it works every day more than 1000 files are uploaded and it is complicated when this happen
Which files are affected by this bug
files with 10MB
Operating system
Windows
Which version of the operating system you are running.
windows 11
Package
Official SNAP package
Nextcloud Server version
28.0.1
Nextcloud Desktop Client version
3.11.1
Is this bug present after an update or on a fresh install?
Fresh desktop client install
Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
