vascocb
1
Clean curl installation on Debian 10 x86_64
When I run nc-encrypt always stops with the following error:
[ nc-encrypt ] (Wed Nov 3 10:10:45 WET 2021)
/usr/local/bin/ncp/SECURITY/nc-encrypt.sh: line 71: PASSWORD: unbound variable
Got empty Password from stdin
I was just using this yesterday and I am not getting that. Are you sure you are on the latest NCP version?
You can also verify that you have a PASSWORD
field in /usr/local/etc/ncp-config.d/nc-encrypt.cfg
Yes, v1.43.3
But I think I found the problem.
The password must be alphanumeric, no special characters
did you have a space on it?
No
the password causing the error is
MyGq%Zb7SX$z*Zk3PJG&KQ$Y8$acbR^7biu88m24!#Gp5GK4sWPsETd9yWpu
At this moment I’m using an alphanumeric password and is working without problems
Maybe the symbol in between the R and 7 in the midle
Without thas symbol it doesn’t work either.
Will be one of the others
danhi
15
Heya, got this error when running nc-encrypt:
Invalid mountpoint: stat /var/www/nextcloud/data: no such file or directory
My data dir is on an external drive… at:
/media/nc_datadrive/ncdata/
