Error: »The PHP module "imagick" is not enabled although« despite module php-imagick is installed and enabled
Please note: I know about the potential security issues of Imagick, but my NC instance is not accessible from the internet. Please refrain from suggesting that I shouldn’t use Imagick. Thank you very much!
Nextcloud Server version (e.g., 29.x.x): 34.0.4
Operating system and version: NextcloudPi v1.58.0
Web server and version (e.g, Apache 2.4.25): Apache/2.4.68 (Debian)
PHP version (e.g, 8.3): PHP 8.4.25
Is this the first time you’ve seen this error? No
When did this problem seem to first start? Since the start of the NC instance
Installation method: NextcloudPi-Image
Are you using CloudfIare, mod_security, or similar? No
Summary of the issue: Ever since the start of the NC instance I see the error »PHP Imagick module | The PHP module “imagick” is not enabled although the theming app is. For favicon generation to work correctly, you need to install and enable this module.« Because I use the App Memories, which for certain functionalities requires Imagick, I finally would like to use Imagick.
So I installed Imagick and Imagemagick by the following commands (found commands after extensive online search):
sudo apt-get install imagemagick imagemagick-6-doc imagemagick-7-doc
sudo apt install php8.4-imagick libmagickcore-dev libmagickwand-dev -y
Because this didn’t make the error in the administrator overview go away, I uninstalled and purged ImageMagick and PHP-Imagick:
sudo apt remove imagemagick
sudo apt remove php-imagick
Then install them again using:
sudo apt install php-imagick imagemagick
I checked if the Imagick module was enabled - it indeed is:
But the error did not go away.
Then I reloaded Apache2. But the error did not go away.
Then I rebooted the Raspberry Pi. But the error did not go away.
The Memories app also says, the Imagick module was not available.
I’m at my wits’ end. I would appreciate, if someone could help me with this matter. Thanks in advance!
NCP is still PHP 8.3 based (to the best of my knowledge) so you likely need php8.3-imagick (and may want to cleanup the different versions to avoid confusion).
Also FPM based so restarting Apache alone will be insufficient (I realize you also rebooted, but noting since it is relevant to further troubleshooting).
Omg that did the trick! The error in the administrator overview is gone and e.g. I now am abled to edit pics in Memories. Thank you very much!
