Error on maintenance:repair --includeexpensive after upgrade to 33.0 (docker)
    • 33.0
    • Unraid (docker) 7.2.4 (Linux 6.12.54-Unraid x86_64)
    • unsure
    • none
    • 8.3.26
    • Yes
    • After upgrade from 32 to 33
    • Docker
After upgrade to 33 from 32, ran “occ maintenance:repair --include-expensive” to upgrade Mime types. I see the following error in the console:
In SimpleContainer.php line 138:
Could not resolve OCA\Files_Sharing\Repair\CleanupShareTarget! Class “OCA\Files_Sharing\Repair\CleanupShareTarget” does not exist
  1. Upgrade using Unraid Community Applications
  2. In console of the docker container, run occ maintenance:repair --include-expensive”
Don't see any relevant log entries.
PASTE
PASTE HERE
        "htaccess.RewriteBase": "\/",
        "trashbin_retention_obligation": "disabled",
        "redis": {
            "port": 6379
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "upgrade.disable-web": true,
            "192.168.1.6:8666"
        "dbtype": "mysql",
        "version": "33.0.0.16",
        "overwrite.cli.url": "http:\/\/192.168.1.6:8666",
        "mysql.utf8mb4": true,
        "defaultapp": "files,dashboard",
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "twofactor_enforced": "true",
            "Users"
        "app_install_overwrite": [],
        "loglevel": 2,
        "config_preset": 1,
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_smtpauth": true,
        "mail_smtpport": "465",
        "mail_sendmailmode": "smtp",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": false,
                "verify_peer": true,
                "verify_peer_name": true
        "serverid": "nextcloud7ub"
  - activity: 6.0.0-dev.0
  - bruteforcesettings: 6.0.0-dev.0
  - cloud_federation_api: 1.17.0
  - dav: 1.36.0
  - federatedfilesharing: 1.23.0
  - files: 2.5.0
  - files_external: 1.25.1
  - files_fulltextsearch: 33.0.0
  - files_pdfviewer: 6.0.0-dev.0
  - files_versions: 1.26.0
  - firstrunwizard: 6.0.0-dev.0
  - fulltextsearch: 33.0.0
  - fulltextsearch_elasticsearch: 33.0.0
  - logreader: 6.0.0
  - lookup_server_connector: 1.21.0
  - notifications: 6.0.0
  - oauth2: 1.21.0
  - password_policy: 5.0.0-dev.0
  - profile: 1.2.0
  - provisioning_api: 1.23.0
  - serverinfo: 5.0.0-dev.0
  - settings: 1.16.0
  - suspicious_login: 11.0.0-dev.0
  - theming: 2.8.0
  - thesearchpage: 2.1.1
  - twofactor_backupcodes: 1.22.0
  - twofactor_totp: 15.0.0-dev.0
  - twofactor_webauthn: 2.6.0
  - updatenotification: 1.23.0
  - viewer: 6.0.0-dev.0
  - workflowengine: 2.15.0
  - admin_audit: 1.23.0
  - app_api: 33.0.0 (installed 33.0.0)
  - circles: 33.0.0 (installed 32.0.0)
  - comments: 1.23.0 (installed 1.22.0)
  - contactsinteraction: 1.14.1 (installed 1.13.1)
  - dashboard: 7.13.0 (installed 7.12.0)
  - encryption: 2.21.0
  - federation: 1.23.0 (installed 1.22.0)
  - files_downloadlimit: 5.1.0-dev.0 (installed 5.0.0-dev.0)
  - files_reminders: 1.6.0 (installed 1.5.0)
  - files_sharing: 1.25.2 (installed 1.24.1)
  - files_trashbin: 1.23.0 (installed 1.22.0)
  - fulltextsearch_sql: 1.3.3 (installed 1.3.3)
  - limit_login_to_ip: 4.3.0 (installed 4.3.0)
  - nextcloud_announcements: 5.0.0 (installed 4.0.0)
  - photos: 6.0.0-dev.0 (installed 5.0.0)
  - privacy: 5.0.0-dev.0 (installed 4.0.0)
  - recommendations: 6.0.0-dev.0 (installed 5.0.0)
  - related_resources: 4.0.0-dev.0 (installed 3.0.0)
  - sharebymail: 1.23.0 (installed 1.22.0)
  - support: 5.0.0 (installed 4.0.0)
  - survey_client: 5.0.0-dev.0 (installed 4.0.0)
  - systemtags: 1.23.0 (installed 1.22.0)
  - text: 7.0.0-dev.3 (installed 6.0.1)
  - twofactor_admin: 4.9.0 (installed 4.9.0)
  - twofactor_nextcloud_notification: 7.0.0 (installed 7.0.0)
  - user_ldap: 1.24.0
  - user_status: 1.13.0 (installed 1.12.0)
  - weather_status: 1.13.0 (installed 1.12.0)
  - webhook_listeners: 1.5.0 (installed 1.3.0)
It’s a known issue if you have the files_sharing app disabled like you do. Next maintainance release will have the fix in it. You can also search the Server GitHub repo if you want to manually patch (or enable the app temporarily).
Thanks! Re-enabling the file sharing app did the trick.
