nextcloud version 13.0.4
Operating system and version Debian Stretch (9.04) stable
Apache or nginx version Apache 2.4.25
PHP version 7.0
when adding or enabling apps for nextcloud, getting those errors
Is this the first time you’ve seen this error? (Y/N):N
- add or enable an app
Error core Error while running background job (InvalidArgumentException): Invalid serialized command 2018-07-05T12:09:47+0200
Error core Error while running background job (InvalidArgumentException): Invalid serialized command 2018-07-05T12:09:44+0200
Error core Error while running background job (InvalidArgumentException): Invalid serialized command 2018-07-05T12:09:26+0200
Error PHP closedir() expects parameter 1 to be resource, boolean given at /var/www/html/apps/files_snapshots/lib/SnapshotManager.php#62 2018-07-05T12:09:22+0200
Error PHP readdir() expects parameter 1 to be resource, boolean given at /var/www/html/apps/files_snapshots/lib/SnapshotManager.php#56 2018-07-05T12:09:22+0200
Error PHP Undefined offset: 1 at /var/www/html/apps/files_snapshots/lib/SnapshotManager.php#48 2018-07-05T12:09:22+0200
Error core Error while running background job (InvalidArgumentException): Invalid serialized command 2018-07-05T12:09:15+0200
Error PHP closedir() expects parameter 1 to be resource, boolean given at /var/www/html/apps/files_snapshots/lib/SnapshotManager.php#62 2018-07-05T12:09:03+0200
Error PHP readdir() expects parameter 1 to be resource, boolean given at /var/www/html/apps/files_snapshots/lib/SnapshotManager.php#56 2018-07-05T12:09:03+0200
'instanceid' => 'redacted',
'passwordsalt' => 'redacted',
'secret' => 'redacted',
0 => 'redacted.ovh',
'datadirectory' => '/mnt/raid6/nextcloud',
'overwrite.cli.url' => 'https://redacted.ovh',
'version' => '13.0.4.0',
'dbname' => 'nextcloudDB',
'dbhost' => 'localhost:3306',
'dbuser' => 'oc_nextadmin',
'dbpassword' => 'redacted',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'tech',
'mail_domain' => 'redacted',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.sendgrid.net',
'mail_smtpport' => '465',
'mail_smtpname' => 'apikey',
'mail_smtppassword' => 'redacted
'loglevel' => 1,
