Hey Everbody,
after i tried a nextcloudpi on my pi, i fully installed a Ubuntu18.04-LAMP (Apache2, PHP7.2, MariaDB 10.1.44) on a external hoster.
Now i’m done but i habe some issues and und errors in my Admin-Logs:
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing ‘SELECT
uid,displaynameFROMoc_usersuLEFT JOINoc_preferencespON (userid=uid) AND (appid= ‘settings’) AND (configkey= ‘email’) WHERE (uidCOLLATE utf8mb4_general_ci LIKE ?) OR (displaynameCOLLATE utf8mb4_general_ci LIKE ?) OR (configvalueCOLLATE utf8mb4_general_ci LIKE ?) ORDER BYuid_lowerASC LIMIT 500 OFFSET 500’ with params [“%%”, “%%”, “%%”]: SQLSTATE[42000]: Syntax error or access violation: 1253 COLLATION ‘utf8mb4_general_ci’ is not valid for CHARACTER SET ‘utf8’
I think its the MariaDB that generate these problems.
In the official Manuel:
https://docs.nextcloud.com/server/16/admin_manual/configuration_database/linux_database_configuration.html
They Write:
Your
/etc/mysql/my.cnfcould look like this:…
But in my case there are only a Default-Text:
The MariaDB configuration file…
And when i’m running maintenance:repair i get 3 Error-Messages:
An exception occurred while executing ‘ALTER TABLE
oc_addressbooksCONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb
4_bin;’:SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
In PDOStatement.php line 119:
In PDOStatement.php line 117:
Could anyone help?
Is it possible to repair the Database or install just the Database new without the rest?
There are no files on the cloud yet. What is the best way to troubleshoot this?
