Error in settings/admin/overview in AIO
    • 10.5.0
    • TrueNas Scale 24.10.2 Ubuntu 24.04 VM
    • Apache 2.4.63
    • pfsense HAProxy 2.8.3-86e043a
    • 8.3.16
    • After clean install
    • AIO
    • cloudflare for DNS of my domain
[Error in logs]
  1. Clean install and go to mydomain.com/settings/admin/overview
	from ? by -- at Feb 8, 2025, 9:56:29 AM```
#### Nextcloud
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the *Copy raw* option from *Administration settings->Logging* screen or from your `nextcloud.log` located in your data directory). Feel free to use a pastebin/gist service if necessary.
```{"reqId":"HSQBUQmUjC60OenOMhdB","level":3,"time":"2025-02-08T14:56:29+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 120, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"30.0.5.1","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocupldzb39sw/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":141,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocupldzb39sw/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":114,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocupldzb39sw/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":151,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":83,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":62,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":61,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[{"stage":"prepare"}]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":43,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"}]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":29,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"}]},{"file":"/var/www/html/cron.php","line":162,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"}]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":187,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 120, arguments: {\"stage\":\"prepare\"})","exception":[],"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 120, arguments: {\"stage\":\"prepare\"})"},"id":"67a7937bb1f82"}```
#### Web Browser
If the problem is related to the Web interface, open your browser inspector *Console* and *Network* tabs while refreshing (reloading) and reproducing the problem. Provide any relevant output/errors here that appear.
PASTE
#### Web server / Reverse Proxy
The output of your Apache/nginx/system log in `/var/log/____`:
```_gateway - - [08/Feb/2025:14:45:50 +0000] "GET / HTTP/1.1" 302 - "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /setup HTTP/1.1" 200 1575 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /style.css?v4 HTTP/1.1" 200 14959 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /forms.js HTTP/1.1" 200 2798 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /toggle-dark-mode.js HTTP/1.1" 200 1491 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /img/nextcloud-logo.svg HTTP/1.1" 200 3090 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /img/jenna-kim-the-globe.webp HTTP/1.1" 200 98876 "https://192.168.5.217:7080/style.css?v4" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:50 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /login HTTP/1.1" 200 1759 "https://192.168.5.217:7080/setup" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /style.css?v4 HTTP/1.1" 200 14959 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /forms.js HTTP/1.1" 200 2798 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /toggle-dark-mode.js HTTP/1.1" 200 1491 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /before-unload.js HTTP/1.1" 200 120 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /img/nextcloud-logo.svg HTTP/1.1" 200 3090 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:45:56 +0000] "GET /img/jenna-kim-the-globe.webp HTTP/1.1" 200 98876 "https://192.168.5.217:7080/style.css?v4" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:01 +0000] "POST /api/auth/login HTTP/1.1" 201 - "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:01 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:01 +0000] "GET /containers HTTP/1.1" 200 12730 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /containers HTTP/1.1" 200 12730 "https://192.168.5.217:7080/login" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /style.css?v4 HTTP/1.1" 200 14959 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /forms.js HTTP/1.1" 200 2798 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /toggle-dark-mode.js HTTP/1.1" 200 1491 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /second-tab-warning.js HTTP/1.1" 200 443 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /timezone.js HTTP/1.1" 200 240 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /before-unload.js HTTP/1.1" 200 120 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:16 +0000] "GET /img/jenna-kim-the-globe.webp HTTP/1.1" 200 98876 "https://192.168.5.217:7080/style.css?v4" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:30 +0000] "POST /api/configuration HTTP/1.1" 201 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:30 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:31 +0000] "GET /containers HTTP/1.1" 200 13165 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:31 +0000] "GET /options-form-submit.js?v3 HTTP/1.1" 200 2446 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
192.168.5.1 - - [08/Feb/2025:14:46:36 +0000] "-" 408 - "-" "-"
_gateway - - [08/Feb/2025:14:46:40 +0000] "POST /api/configuration HTTP/1.1" 201 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:40 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:40 +0000] "GET /containers HTTP/1.1" 200 13165 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:46 +0000] "POST /api/configuration HTTP/1.1" 201 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:46 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:46 +0000] "GET /containers HTTP/1.1" 200 12264 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:46:51 +0000] "POST /api/docker/start HTTP/1.1" 201 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /disable-clamav.js HTTP/1.1" 200 161 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /disable-docker-socket-proxy.js HTTP/1.1" 200 249 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /disable-talk.js HTTP/1.1" 200 153 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /disable-imaginary.js HTTP/1.1" 200 177 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /automatic_reload.js HTTP/1.1" 200 678 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:36 +0000] "GET /disable-collabora.js HTTP/1.1" 200 173 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:37 +0000] "GET /disable-talk-recording.js HTTP/1.1" 200 153 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:37 +0000] "GET /disable-whiteboard.js HTTP/1.1" 200 178 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:37 +0000] "GET /disable-fulltextsearch.js HTTP/1.1" 200 198 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:37 +0000] "GET /disable-onlyoffice.js HTTP/1.1" 200 215 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:42 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:42 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:47 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:47 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:52 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:52 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
192.168.5.1 - - [08/Feb/2025:14:49:57 +0000] "-" 408 - "-" "-"
_gateway - - [08/Feb/2025:14:49:57 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:49:58 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:03 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:03 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:08 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:08 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:13 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:14 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:19 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:19 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:24 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:24 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:29 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:29 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:32 +0000] "GET /containers HTTP/1.1" 200 16219 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:32 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:37 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:38 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:43 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:43 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:48 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:48 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:53 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:53 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:58 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:50:59 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:04 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:04 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:09 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:09 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:14 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:15 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:20 +0000] "GET /containers HTTP/1.1" 200 16219 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:20 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:24 +0000] "GET /containers HTTP/1.1" 200 16219 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:25 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:30 +0000] "GET /containers HTTP/1.1" 200 16218 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:30 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:35 +0000] "GET /containers HTTP/1.1" 200 24206 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:35 +0000] "GET /img/favicon.png HTTP/1.1" 200 90022 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:56 +0000] "POST /api/configuration HTTP/1.1" 201 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:56 +0000] "GET / HTTP/1.1" 302 - "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:14:51:56 +0000] "GET /containers HTTP/1.1" 200 26240 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
_gateway - - [08/Feb/2025:17:19:43 +0000] "GET /api/docker/logs?id=nextcloud-aio-apache HTTP/1.1" 200 2221 "https://192.168.5.217:7080/containers" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"```
### Configuration
#### Nextcloud
The output of `occ config:list system` or similar is best, but, if not possible, the contents of your `config.php` file from `/path/to/nextcloud` is fine (make sure to remove any identifiable information!):
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nc.warrenbuc.com",
        "overwriteprotocol": "https",
            "localhost",
            "nc.warrenbuc.com"
        "dbtype": "pgsql",
        "version": "30.0.5.1",
        "overwrite.cli.url": "https:\/\/nc.warrenbuc.com\/",
        "dbport": "",
        "loglevel": 2,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "default_phone_region": "US",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "DOMAIN": "mydomain.com"
#### Apps
The output of `occ app:list` (if possible).
  • activity: 3.0.0
  • admin_audit: 1.20.0
  • bruteforcesettings: 3.0.0
  • calendar: 5.0.9
  • circles: 30.0.0
  • cloud_federation_api: 1.13.0
  • comments: 1.20.1
  • contacts: 6.1.3
  • contactsinteraction: 1.11.0
  • dashboard: 7.10.0
  • dav: 1.31.1
  • deck: 1.14.3
  • federatedfilesharing: 1.20.0
  • federation: 1.20.0
  • files: 2.2.0
  • files_downloadlimit: 3.0.0
  • files_pdfviewer: 3.0.0
  • files_reminders: 1.3.0
  • files_sharing: 1.22.0
  • files_trashbin: 1.20.1
  • files_versions: 1.23.0
  • firstrunwizard: 3.0.0
  • logreader: 3.0.0
  • lookup_server_connector: 1.18.0
  • nextcloud-aio: 0.7.0
  • nextcloud_announcements: 2.0.0
  • notes: 4.11.0
  • notifications: 3.0.0
  • notify_push: 1.0.0
  • oauth2: 1.18.1
  • password_policy: 2.0.0
  • photos: 3.0.2
  • privacy: 2.0.0
  • provisioning_api: 1.20.0
  • recommendations: 3.0.0
  • related_resources: 1.5.0
  • richdocuments: 8.5.3
  • serverinfo: 2.0.0
  • settings: 1.13.0
  • sharebymail: 1.20.0
  • support: 2.0.0
  • survey_client: 2.0.0
  • systemtags: 1.20.0
  • tasks: 0.16.1
  • text: 4.1.0
  • theming: 2.5.0
  • twofactor_backupcodes: 1.19.0
  • twofactor_totp: 12.0.0-dev
  • user_status: 1.10.0
  • viewer: 3.0.0
  • weather_status: 1.10.0
  • webhook_listeners: 1.1.0-dev
  • whiteboard: 1.0.5
  • workflowengine: 2.12.0
  • app_api: 4.0.5 (installed 4.0.5)
  • encryption: 2.18.0
  • files_external: 1.22.0
  • suspicious_login: 8.0.0
  • twofactor_nextcloud_notification: 4.0.0
  • user_ldap: 1.21.0
### Tips for increasing the likelihood of a response
* Use the `preformatted text` formatting option in the editor for all log entries and configuration output.
* If screenshots are useful, feel free to include them.
  - If possible, also include key error output in text form so it can be searched for.
* Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
Is it only once right after initial installation? If so, you can safely ignore it.
Got the same error 3 times at 9:51, 9:51 and 9:56 today
