I have cleared storage for the apps in the movile phone, both nextcloud and deck, then unistalled them, then install them again from fdroid.
Then I go to add account, I have tried with a QR or with login with both apps, it seems the same in the four cases.
I hace changed in config.php errorlevel from 3 to 0, restarted apache and try to log from deck.
I am at the login screen, I enter username and password, then when I click the login button
{"reqId":"RT3Aoo1nTIF8dRZS2TFr","level":0,"time":"2023-04-04T15:27:38+00:00","remoteAddr":"90.167.218.101","user":"--","app":"gpxedit","method":"POST","url":"/nextcloud/index.php/login","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"gpxedit"}}
{"reqId":"RT3Aoo1nTIF8dRZS2TFr","level":0,"time":"2023-04-04T15:27:39+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"suspicious_login","method":"POST","url":"/nextcloud/index.php/login","message":"loading latest model","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"suspicious_login"}}
{"reqId":"RT3Aoo1nTIF8dRZS2TFr","level":0,"time":"2023-04-04T15:27:39+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"suspicious_login","method":"POST","url":"/nextcloud/index.php/login","message":"using cached model 305","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"suspicious_login"}}
{"reqId":"RT3Aoo1nTIF8dRZS2TFr","level":0,"time":"2023-04-04T15:27:39+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"suspicious_login","method":"POST","url":"/nextcloud/index.php/login","message":"seralized model size: 212480","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"suspicious_login"}}
{"reqId":"RT3Aoo1nTIF8dRZS2TFr","level":0,"time":"2023-04-04T15:27:39+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"suspicious_login","method":"POST","url":"/nextcloud/index.php/login","message":"Ip 90.167.218.101 for user fernando is not suspicious","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"suspicious_login"}}
{"reqId":"blHI124YU4aYdA8Uro1Z","level":0,"time":"2023-04-04T15:27:40+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"gpxedit","method":"GET","url":"/nextcloud/index.php/login/flow/grant?clientIdentifier=&user=&direct=0&stateToken=x5bJLTFiwaTRqSacZkqLbkkJTZnjp6dAGNXTomKo1D7RlW87HXXEv6OzZpQfLQYM","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"gpxedit"}}
{"reqId":"R7ZriehEPoll0azvxLCx","level":0,"time":"2023-04-04T15:27:41+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"gpxedit","method":"GET","url":"/nextcloud/index.php/core/js/oc.js?v=1edc5733","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"gpxedit"}}
Then the grant access screen appear, I click the grant access button
{"reqId":"v0OFxzvDajUE9d3AmNhn","level":0,"time":"2023-04-04T15:28:09+00:00","remoteAddr":"90.167.218.101","user":"fernando","app":"gpxedit","method":"POST","url":"/nextcloud/index.php/login/flow","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Bq Aquaris U (Android)","version":"25.0.5.1","data":{"app":"gpxedit"}}
{"reqId":"lcPI1Nh5rHOGNAjUfGBq","level":0,"time":"2023-04-04T15:28:10+00:00","remoteAddr":"90.167.218.101","user":"--","app":"webdav","method":"HEAD","url":"/nextcloud/remote.php/dav","message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.24.1","version":"25.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","Code":0,"Trace":[{"file":"/srv/www/htdocs/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/srv/www/htdocs/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/srv/www/htdocs/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/srv/www/htdocs/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/srv/www/htdocs/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/srv/www/htdocs/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/srv/www/htdocs/nextcloud/remote.php","line":171,"args":["/srv/www/htdocs/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/srv/www/htdocs/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","Line":152,"message":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured","exception":{},"CustomMessage":"No public access to this resource., No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Bearer' header found. Either the client didn't send one, or the server is mis-configured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured"}}
{"reqId":"ll47LDvCacj5pTIf6U7w","level":0,"time":"2023-04-04T15:28:10+00:00","remoteAddr":"90.167.218.101","user":"--","app":"gpxedit","method":"GET","url":"/nextcloud/ocs/v2.php/cloud/user?format=json","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.24.1","version":"25.0.5.1","data":{"app":"gpxedit"}}
The deck says “Error: you have to accept required rights to use the single-sign-on characteristic” (maybe something slightly different, I have translated it)
In the middle of both there where things originated by some other computer in my local network (identified by a local ip), I have clean them from the log to post here, I think I clean them all and only them.
But I have davx5 app in the phone connecting to the server using the calendar and working ok.
I s taht suspicious_login?
