Error HTTP 403 and 404 after trying a workaround to make occ work
    • 30
    • Debian 12
    • NGINX 1.22.1-9
    • NGINX 1.22.1-9
    • 8.3
    • no
    • The first time i launched the command
    • Installation script
    • no
I’d like to use the occ command to perform some maintenance, but i’m facing error messages.
Could not open input file: occ
I tried a workaround mentioned here and typed the command chmod 744 /var/www/nextcloud, but it’s getting worse: now i have HTTP 403 and 404 errors. How to fix this ?
  1. Try a command implying occ
  2. chmod 744 /var/www/nextcloud
PASTE HERE
first fix your permissions:
undo your chmod 744 this is should be best at 750 drwxr-x—
How did you run the command?
And for the record, that’s not what that linked post says to do. :wink:
The chmod target is occ not the folder.
You might also find the chapter covering occ of interest: Admin Manual: Using the occ command
