Hallo zusammen
Ich wollte heute ein Img über 4 Giga gross hochladen und erhielt eine Fehlermeldung.
Alles was unter 4 G ist wird ohne weiteres hochgeladen.
Hier die Meldung:
Sabre\DAV\Exception: Error while copying file to target location (copied bytes: 0, expected filesize: -1 )
- /snap/nextcloud/16740/htdocs/apps/dav/lib/Connector/Sabre/Directory.php - line 156: OCA\DAV\Connector\Sabre\File->put(null)
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/Tree.php - line 316: OCA\DAV\Connector\Sabre\Directory->createFile(“en_windows_ … o”, null)
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/Tree.php - line 130: Sabre\DAV\Tree->copyNode(OCA\DAV\Upload\FutureFile {}, OCA\DAV\Conn … {}, “en_windows_ … o”)
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/Tree.php - line 161: Sabre\DAV\Tree->copy(“uploads/pi/ … e”, “files/pi/So … o”)
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 642: Sabre\DAV\Tree->move(“uploads/pi/ … e”, “files/pi/So … o”)
- <>Sabre\DAV\CorePlugin->httpMove(Sabre\HTTP\R … "}, Sabre\HTTP\Response {})
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array([ Sabre\DAV\ … "], [ Sabre\HTTP … }])
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit(“method:MOVE”, [ Sabre\HTTP … }])
- /snap/nextcloud/16740/htdocs/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Sabre\HTTP\R … "}, Sabre\HTTP\Response {})
- /snap/nextcloud/16740/htdocs/apps/dav/lib/Server.php - line 316: Sabre\DAV\Server->exec()
- /snap/nextcloud/16740/htdocs/apps/dav/appinfo/v2/remote.php - line 35: OCA\DAV\Server->exec()
- /snap/nextcloud/16740/htdocs/remote.php - line 163: require_once("/snap/nextc … p")
Danke und Gruss, Mancomx
