Hello everyone,
after a linux crash (UBUNTU 20.04 LTS) that deleted the logs folder (/ var / log), I can’t start Nextcloud anymore.
I try to run OCC to repair, and it gives me this error, without telling me which file or directory is missing:
sudo -u www-data php /var/www/nextcloud/occ
RedisException: No such file or directory in /var/www/nextcloud/lib/private/RedisFactory.php:124
Stack trace:
#0 /var/www/nextcloud/lib/private/RedisFactory.php(124): Redis->connect()
#1 /var/www/nextcloud/lib/private/RedisFactory.php(164): OC\RedisFactory->create()
#2 /var/www/nextcloud/lib/private/Memcache/Redis.php(43): OC\RedisFactory->getInstance()
#3 /var/www/nextcloud/lib/private/Memcache/Factory.php(115): OC\Memcache\Redis->__construct()
#4 /var/www/nextcloud/lib/private/Server.php(1065): OC\Memcache\Factory->createLocking()
#5 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC{closure}()
#6 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}()
#7 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#8 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#9 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#10 /var/www/nextcloud/lib/private/Server.php(2024): OC\AppFramework\Utility\SimpleContainer->get()
#11 /var/www/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#12 /var/www/nextcloud/lib/private/Server.php(435): OC\Files\View->__construct()
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC{closure}()
#14 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}()
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#16 /var/www/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#18 /var/www/nextcloud/lib/private/Server.php(1387): OC\AppFramework\Utility\SimpleContainer->get()
#19 /var/www/nextcloud/lib/base.php(594): OC\Server->boot()
#20 /var/www/nextcloud/lib/base.php(1083): OC::init()
#21 /var/www/nextcloud/console.php(48): require_once(’/var/www/nextcl…’)
#22 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
#23 {main}root@cloudio:/var/log/nextcloud# ^C
Furthermore, despite having set the LogLevels on config.php to a value of 0, they always appear at level 3 in the log .
I have nextcloud totally blocked and I don’t know which way to turn
Thanks in advance for your help
