Nextcloud version: 20
Operating system and version : Synology DSM 6.2.3
HAProxy Docker:latest
My Nextcloud installation runs smoothly behind a HAProxy setup that redirects to https. I can use my nextcloud within the local network with the local IP and outside with a dyndns adress.
However, is recently tried to connect my nextcloud account with an app to synchronize data. In the app (called Docutain, a smartphone scanner app) I received the following error:
OPTIONS /login ERROR 405 Method Not Allowed
In the mentioned app I try to connect to:
https://my-nextcloud-domain.com
I also tried
http://my-nextcloud-domain.com
and even
http://192.168.0.237:8080
Here is my config.php file:
<?PHP
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => '123id123',
'passwordsalt' => 'xyzpasswordxyz',
'secret' => 'xyzsecretxyz',
0 => 'my-nextcloud-domain.com',
1 => '192.168.0.237:8080',
3 => '192.168.0.237:81',
4 => '172.17.0.1',
'overwritehost' => 'my-nextcloud-domain.com',
'version' => '20.0.5.2',
'overwrite.cli.url' => 'http://192.168.0.237:8080',
'dbname' => 'nextcloud',
'dbhost' => '192.168.0.237:3306',
'dbuser' => 'admin',
'dbpassword' => 'adminpassword',
'loglevel' => 2,
How could I solve this issue?
