Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 29.0.5): 29.04
Operating system and version (eg, Ubuntu 24.04): Ubuntu 24.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.58
PHP version (eg, 8.3): 8.3
NGINX Version: 1.18.0
I (and my users) can access and use the web interface fine, same with the nextcloud windows and OSX clients but using CyberDuck for DAV access fails with an error 405 Method Not Allowed response.
I’ve adjusted the path URL to different permutations and also copied the DAV url link from the nextcloud login in the lower left corner but still can’t use it.
- Use any webdav client, authenticate with valid credentials, get error.
- Change path to manually provide it - get same error.
No references to issue in Nextcloud Log.
N/A
No references to issue in NGINX log or Apache.
Here's my NGINX Config:
server {
server_name xxxxx.xxxxx.com;
location / {
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-Host $remote_addr;
proxy_pass http://10.X.X.X.;
proxy_buffering off;
# Timeouts, give up to 5 minutes for slow apps.
proxy_connect_timeout 600;
proxy_send_timeout 600;
send_timeout 600;
proxy_read_timeout 600;
fastcgi_read_timeout 600;
location /.well-known/carddav {
location /.well-known/caldav {
#Logging:
access_log /var/log/nextcloud/access.log;
error_log /var/log/nextcloud/error.log;
listen [::]:443 ssl; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/xxxxx.xxxxx.com-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/xxxxxx.xxxxxxx.com-0001/privkey.pem; # managed by Certbot
# include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
# ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
# add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
server {
if ($host = xxxxx.xxxxxxxx.com) {
} # managed by Certbot
server_name xxxxx.xxxxxx.com;
listen [::]:80;
listen 80;
