Bonjour ,
Jâai bien entendu chercher ma rĂ©ponse sur le Forum et partout sur le web mais vu le nombre de possibilitĂ© pour la mĂȘme erreur, je nâai pas rĂ©ussi Ă trouver mon bonheurâŠ
Le problĂšme que je rencontre câest dâavoir un message dâerreur âErreur lors de lâassemblage des blocs, code dâĂ©tat 504â (( Error when assembling chunks, status code 504 )) Ă la fin de lâenvoi dâun gros fichier ( 7Gb ) pour le test (( 3Gb passe correctement ))
Je suis sur Docker, et je passe par un reverse proxy SWAG
Merci dâavance pour votre aide
nginx.conf
## Version 2023/04/13 - Changelog: https://github.com/linuxserver/docker-baseimage-alpine-nginx/commits/master/root/defaults/nginx/nginx.conf.sample
### Based on alpine defaults
# https://git.alpinelinux.org/aports/tree/main/nginx/nginx.conf?h=3.15-stable
user abc;
# Set number of worker processes automatically based on number of CPU cores.
include /config/nginx/worker_processes.conf;
# Enables the use of JIT for regular expressions to speed-up their processing.
pcre_jit on;
# Configures default error logger.
error_log /config/log/nginx/error.log;
# Includes files with directives to load dynamic modules.
include /etc/nginx/modules/*.conf;
# Include files with config snippets into the root context.
include /etc/nginx/conf.d/*.conf;
events {
# The maximum number of simultaneous connections that can be opened by
# a worker process.
worker_connections 1024;
http {
# Includes mapping of file name extensions to MIME types of responses
# and defines the default type.
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Name servers used to resolve names of upstream servers into addresses.
# It's also needed when using tcpsocket and udpsocket in Lua modules.
#resolver 1.1.1.1 1.0.0.1 2606:4700:4700::1111 2606:4700:4700::1001;
include /config/nginx/resolver.conf;
# Don't tell nginx version to the clients. Default is 'on'.
server_tokens off;
# Specifies the maximum accepted body size of a client request, as
# indicated by the request header Content-Length. If the stated content
# length is greater than this size, then the client receives the HTTP
# error code 413. Set to 0 to disable. Default is '1m'.
client_max_body_size 0;
# Sendfile copies data between one FD and other from within the kernel,
# which is more efficient than read() + write(). Default is off.
sendfile on;
# Causes nginx to attempt to send its HTTP response head in one packet,
# instead of using partial frames. Default is 'off'.
tcp_nopush on;
# all ssl related config moved to ssl.conf
# included in server blocks where listen 443 is defined
# Enable gzipping of responses.
#gzip on;
# Set the Vary HTTP header as defined in the RFC 2616. Default is 'off'.
gzip_vary on;
# Helper variable for proxying websockets.
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
# Sets the path, format, and configuration for a buffered log write.
access_log /config/log/nginx/access.log;
# Includes virtual hosts configs.
include /etc/nginx/http.d/*.conf;
include /config/nginx/site-confs/*.conf;
daemon off;
pid /run/nginx.pid;
php-local.ini
; Edit this file to override php.ini directives
date.timezone = Europe/Paris
upload_max_filesize = 50G
post_max_size = 50G
max_input_time = 3600
max_execution_time = 3600
