Erreur 500 après upgrade et erreur Memcache/Redis lors tentative maintenance
Bonjour, après des tentatives d’installations/configuration des modules de reconnaissance faciale et une upgrade j’ai crashé mon serveur (erreur 500).
Je n’y connais rien mais pense avoir un problème de librairie/versions de ph
Voici le contenu du error.log apache2
PHP Warning: PHP Startup: pdlib: Unable to initialize module\nModule compiled with module API=20210902\nPHP compiled with module API=20220829\nThese options need to match\n in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘pdo.so’ (tried: /usr/lib/php/20220829/pdo.so (/usr/lib/php/20220829/pdo.so: undefined symbol: zend_zval_value_name), /usr/lib/php/20220829/pdo.so.so (/usr/lib/php/20220829/pdo.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘pdo_mysql.so’ (tried: /usr/lib/php/20220829/pdo_mysql.so (/usr/lib/php/20220829/pdo_mysql.so: undefined symbol: pdo_parse_params), /usr/lib/php/20220829/pdo_mysql.so.so (/usr/lib/php/20220829/pdo_mysql.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
[Mon Apr 13 00:00:00.892994 2026] [ssl:warn] [pid 7093] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Mon Apr 13 00:00:00.898786 2026] [ssl:warn] [pid 7093] AH01909: homecamsvv.ddns.net:443:0 server certificate does NOT include an ID which matches the server name
[Mon Apr 13 00:00:00.899610 2026] [mpm_prefork:notice] [pid 7093] AH00163: Apache/2.4.58 (Ubuntu) OpenSSL/3.0.13 configured – resuming normal operations
[Mon Apr 13 00:00:00.899647 2026] [core:notice] [pid 7093] AH00094: Command line: ‘/usr/sbin/apache2’
[Mon Apr 13 00:09:38.284173 2026] [php:error] [pid 27656] [client 3.151.241.153:57074] PHP Fatal error: Uncaught Error: Class “PDO” not found in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/MySQL/Driver.php:33\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(377): Doctrine\DBAL\Driver\PDO\MySQL\Driver->connect()\n#1 /var/www/nextcloud/lib/private/DB/Connection.php(144): Doctrine\DBAL\Connection->connect()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1654): OC\DB\Connection->connect()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1081): Doctrine\DBAL\Connection->getWrappedConnection()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(271): Doctrine\DBAL\Connection->executeQuery()\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(337): OC\DB\Connection->executeQuery()\n#6 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(377): Doctrine\DBAL\Query\QueryBuilder->executeQuery()\n#7 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(280): Doctrine\DBAL\Query\QueryBuilder->execute()\n#8 /var/www/nextcloud/lib/private/AppConfig.php(440): OC\DB\QueryBuilder\QueryBuilder->execute()\n#9 /var/www/nextcloud/lib/private/AppConfig.php(206): OC\AppConfig->loadConfigValues()\n#10 /var/www/nextcloud/lib/private/AppConfig.php(396): OC\AppConfig->getApps()\n#11 /var/www/nextcloud/lib/private/legacy/OC_App.php(734): OC\AppConfig->getValues()\n#12 /var/www/nextcloud/lib/private/Server.php(683): OC_App::getAppVersions()\n#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\Server->OC\{closure}()\n#14 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#16 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(197): OC\AppFramework\Utility\SimpleContainer->get()\n#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#20 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#22 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(96): OC\ServerContainer->query()\n#24 [internal function]: OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(83): array_map()\n#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(128): OC\AppFramework\Utility\SimpleContainer->buildClass()\n#27 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(146): OC\AppFramework\Utility\SimpleContainer->resolve()\n#28 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#29 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#30 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(197): OC\AppFramework\Utility\SimpleContainer->get()\n#31 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#32 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#33 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#34 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#35 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#36 /var/www/nextcloud/lib/private/Server.php(523): OC\AppFramework\Utility\SimpleContainer->get()\n#37 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\Server->OC\{closure}()\n#38 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#39 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#40 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#41 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#42 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(197): OC\AppFramework\Utility\SimpleContainer->get()\n#43 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#44 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#45 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#46 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#47 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#48 /var/www/nextcloud/lib/private/Server.php(1347): OC\AppFramework\Utility\SimpleContainer->get()\n#49 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\Server->OC\{closure}()\n#50 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#51 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#52 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#53 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#54 /var/www/nextcloud/lib/private/Server.php(1239): OC\AppFramework\Utility\SimpleContainer->get()\n#55 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(175): OC\Server->OC\{closure}()\n#56 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(122): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#57 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(142): Pimple\Container->offsetGet()\n#58 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#59 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(96): OC\ServerContainer->query()\n#60 [internal function]: OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()\n#61 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(83): array_map()\n#62 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(128): OC\AppFramework\Utility\SimpleContainer->buildClass()\n#63 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(146): OC\AppFramework\Utility\SimpleContainer->resolve()\n#64 /var/www/nextcloud/lib/private/ServerContainer.php(173): OC\AppFramework\Utility\SimpleContainer->query()\n#65 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()\n#66 /var/www/nextcloud/lib/private/Serv
Lorsque j’essaie de mettre le serveur en maintenance j’obtiens ce message.
root@victor-NAS:/var/www/nextcloud# sudo -u www-data php occ maintenance:mode --on
OCP\HintException: [0]: Memcache OC\Memcache\Redis not available for local cache (Is the matching PHP module installed and enabled?)
J’ai essayé d’installer apcu sans + de succès.
J’aimerais ne pas avoir à tout réinstaller. Merci pour votre aide.
