Bonjour,
Je me permets de poster car je viens de changer dâos je suis passĂ© de ubuntu server a FĂ©dora server malheureusement lors de la remise en ligne de mon serveur jâobtien une erreur 500.
Voivi un extrait du log:
{"reqId":"ZNNlP4SQ7w6ehAfHfs8hHgAAAAw","level":3,"time":"2023-08-09T10:07:18+00:00","remoteAddr":"192.168.1.254","user":"Sebastien Obierti","app":"richdocuments","method":"GET","url":"/ocs/v2.php/apps/user_status/api/v1/user_status?format=json","message":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","userAgent":"Mozilla/5.0 (Linux) mirall/3.9.0git (Nextcloud, fedora-6.4.8-200.fc38.x86_64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"25.0.8.2","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","Code":0,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Http/Client/DnsPinMiddleware.php","line":113,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/Service/CapabilitiesService.php","line":136,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/Service/CapabilitiesService.php","line":74,"function":"refetch","class":"OCA\\Richdocuments\\Service\\CapabilitiesService","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/AppInfo/Application.php","line":80,"function":"getCapabilities","class":"OCA\\Richdocuments\\Service\\CapabilitiesService","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"OCA\\Richdocuments\\AppInfo\\{closure}","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/AppInfo/Application.php","line":135,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_App.php","line":208,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_App.php","line":141,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/srv/web/obierti-cloud/ocs/v1.php","line":58,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/srv/web/obierti-cloud/ocs/v2.php","line":23,"args":["/srv/web/obierti-cloud/ocs/v1.php"],"function":"require_once"}],"File":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"message":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","exception":{},"CustomMessage":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities"}}
{"reqId":"ZNNlP-FWG7xzh1owW0TcRgAAAAM","level":3,"time":"2023-08-09T10:07:18+00:00","remoteAddr":"192.168.1.254","user":"Sebastien Obierti","app":"richdocuments","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications?format=json","message":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","userAgent":"Mozilla/5.0 (Linux) mirall/3.9.0git (Nextcloud, fedora-6.4.8-200.fc38.x86_64 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"25.0.8.2","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","Code":0,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Http/Client/DnsPinMiddleware.php","line":113,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Http/Client/Client.php","line":218,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/Service/CapabilitiesService.php","line":136,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/Service/CapabilitiesService.php","line":74,"function":"refetch","class":"OCA\\Richdocuments\\Service\\CapabilitiesService","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/AppInfo/Application.php","line":80,"function":"getCapabilities","class":"OCA\\Richdocuments\\Service\\CapabilitiesService","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":67,"function":"OCA\\Richdocuments\\AppInfo\\{closure}","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":51,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->"},{"file":"/srv/web/obierti-cloud/apps/richdocuments/lib/AppInfo/Application.php","line":135,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":190,"function":"boot","class":"OCA\\Richdocuments\\AppInfo\\Application","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_App.php","line":208,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/legacy/OC_App.php","line":141,"function":"loadApp","class":"OC_App","type":"::"},{"file":"/srv/web/obierti-cloud/ocs/v1.php","line":58,"function":"loadApps","class":"OC_App","type":"::"},{"file":"/srv/web/obierti-cloud/ocs/v2.php","line":23,"args":["/srv/web/obierti-cloud/ocs/v1.php"],"function":"require_once"}],"File":"/srv/web/obierti-cloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"message":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities","exception":{},"CustomMessage":"Failed to fetch the Collabora capabilities endpoint: cURL error 28: Failed to connect to demo.eu.collaboraonline.com port 443 after 22702 ms: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://demo.eu.collaboraonline.com/hosting/capabilities"}}
{"reqId":"ZNTdHJKbFUFnr0hHJ_vmegAAAAQ","level":2,"time":"2023-08-10T12:50:36+00:00","remoteAddr":"192.168.1.254","user":"--","app":"no app in context","method":"POST","url":"/index.php/login","message":"Login failed: S\u00e9bastien O (Remote IP: 192.168.1.254)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/116.0","version":"25.0.8.2","data":[]}
{"reqId":"ZNZ0xcztg8GLsZzI8VWHMwAAAAs","level":3,"time":"2023-08-11T17:49:57+00:00","remoteAddr":"192.168.1.254","user":"Sebastien Obierti","app":"index","method":"GET","url":"/index.php/apps/files_versions/preview?file=%2FAssocadmin%2Faction.km&version=1691074038","message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/116.0","version":"25.0.8.2","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":109,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":98,"function":"insertIgnoreConflict","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":136,"function":"initLockField","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":765,"function":"acquireLock","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":610,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":149,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":31,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":445,"function":"scanFile","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":391,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":342,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":39,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1354,"function":"scan","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1394,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":98,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":147,"function":"getAppDataFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Storage/Root.php","line":74,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":581,"function":"newFolder","class":"OC\\Preview\\Storage\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":137,"function":"getPreviewFolder","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":114,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/PreviewManager.php","line":185,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/apps/files_versions/lib/Controller/PreviewController.php","line":93,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"getPreview","class":"OCA\\Files_Versions\\Controller\\PreviewController","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/srv/web/obierti-cloud/lib/base.php","line":1048,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/srv/web/obierti-cloud/lib/private/DB/Exceptions/DbalException.php","Line":72,"Previous":{"Exception":"Doctrine\\DBAL\\Exception\\DeadlockException","Message":"An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1173,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Adapter.php","line":146,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":360,"function":"insertIgnoreConflict","class":"OC\\DB\\Adapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":107,"function":"insertIgnoreConflict","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":98,"function":"insertIgnoreConflict","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":136,"function":"initLockField","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":765,"function":"acquireLock","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":610,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":149,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":31,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":445,"function":"scanFile","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":391,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":342,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":39,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1354,"function":"scan","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1394,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":98,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":147,"function":"getAppDataFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Storage/Root.php","line":74,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":581,"function":"newFolder","class":"OC\\Preview\\Storage\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":137,"function":"getPreviewFolder","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":114,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/PreviewManager.php","line":185,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/apps/files_versions/lib/Controller/PreviewController.php","line":93,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"getPreview","class":"OCA\\Files_Versions\\Controller\\PreviewController","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/srv/web/obierti-cloud/lib/base.php","line":1048,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":37,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":1213,"Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Adapter.php","line":146,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":360,"function":"insertIgnoreConflict","class":"OC\\DB\\Adapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":107,"function":"insertIgnoreConflict","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":98,"function":"insertIgnoreConflict","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":136,"function":"initLockField","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":765,"function":"acquireLock","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":610,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":149,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":31,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":445,"function":"scanFile","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":391,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":342,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":39,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1354,"function":"scan","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1394,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":98,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":147,"function":"getAppDataFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Storage/Root.php","line":74,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":581,"function":"newFolder","class":"OC\\Preview\\Storage\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":137,"function":"getPreviewFolder","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":114,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/PreviewManager.php","line":185,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/apps/files_versions/lib/Controller/PreviewController.php","line":93,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"getPreview","class":"OCA\\Files_Versions\\Controller\\PreviewController","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/srv/web/obierti-cloud/lib/base.php","line":1048,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction","Code":"40001","Trace":[{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Connection.php","line":1163,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":294,"function":"executeStatement","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":354,"function":"executeStatement","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Adapter.php","line":146,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/Connection.php","line":360,"function":"insertIgnoreConflict","class":"OC\\DB\\Adapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/DB/ConnectionAdapter.php","line":107,"function":"insertIgnoreConflict","class":"OC\\DB\\Connection","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":98,"function":"insertIgnoreConflict","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Lock/DBLockingProvider.php","line":136,"function":"initLockField","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Common.php","line":765,"function":"acquireLock","class":"OC\\Lock\\DBLockingProvider","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":610,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":149,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":31,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":445,"function":"scanFile","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":391,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/Scanner.php","line":342,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Cache/LocalRootScanner.php","line":39,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1354,"function":"scan","class":"OC\\Files\\Cache\\LocalRootScanner","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/View.php","line":1394,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array"},{"file":"/srv/web/obierti-cloud/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":98,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Files/AppData/AppData.php","line":147,"function":"getAppDataFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Storage/Root.php","line":74,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":581,"function":"newFolder","class":"OC\\Preview\\Storage\\Root","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":137,"function":"getPreviewFolder","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Preview/Generator.php","line":114,"function":"generatePreviews","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/PreviewManager.php","line":185,"function":"getPreview","class":"OC\\Preview\\Generator","type":"->"},{"file":"/srv/web/obierti-cloud/apps/files_versions/lib/Controller/PreviewController.php","line":93,"function":"getPreview","class":"OC\\PreviewManager","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"getPreview","class":"OCA\\Files_Versions\\Controller\\PreviewController","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/web/obierti-cloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/srv/web/obierti-cloud/lib/base.php","line":1048,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/srv/web/obierti-cloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/srv/web/obierti-cloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}}},"CustomMessage":"--"}}
{"reqId":"ZNoURXCseuN2Hki9zuP4UwAAAAA","level":2,"time":"2023-08-14T11:47:18+00:00","remoteAddr":"79.208.196.197","user":"--","app":"no app in context","method":"POST","url":"/index.php/login","message":"Login failed: admin (Remote IP: 79.208.196.197)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 Edg/115.0.1901.203","version":"25.0.8.2","data":[]}
Pouvez-vous mâexpliquer comment corriger mon erreur svp ?
Merci pour vos retours.
