example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.3.1
Operating system and version (eg, Ubuntu 20.04): Raspbian 10
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.38
PHP version (eg, 7.4): 7.3.29
Last time I used my Nextcloud was about 2 weeks ago and today I wanted to sync my files again.
First I tried to connect to my nextcloud through the Android App, but it didn’t load. After that, I tried to connect to my Nextcloud via Browser on my PC. That didn’t work aswell. I always get the CONNECTION_TIMED_OUT error.
By the way, I only power up my Raspberry for syncing the files. The rest of the time, the pi is turned off.
Already tried to acces my Nextcloud via different browser and different devices. Nothing works.
When using the command sudo hdparm -C /dev/sda
I get this output:
/dev/sda: SG_IO: bad/missing sense data, sb[]: 70 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 drive state is: unknown
Not sure if this has anything to do with this whole error.
‘datadirectory’ => ‘/media/641bef0a-6fe9-4c6a-95d3-dd62da3eaca2/ncdata’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘21.0.3.1’,
‘dbname’ => ‘nextcloud’,
‘dbhost’ => ‘localhost’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘mysql.utf8mb4’ => true,
‘dbuser’ => ‘ncadmin’,
‘installed’ => true,
‘instanceid’ => ‘oc7n3v2e3tzx’,
‘memcache.local’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
‘host’ => ‘/var/run/redis/redis.sock’,
‘port’ => 0,
‘timeout’ => 0.0,
‘tempdirectory’ => ‘/media/641bef0a-6fe9-4c6a-95d3-dd62da3eaca2/ncdata/tmp’,
‘mail_smtpmode’ => ‘sendmail’,
‘mail_smtpauthtype’ => ‘LOGIN’,
‘mail_from_address’ => ‘admin’,
‘mail_domain’ => ‘ownyourbits.com’,
‘preview_max_x’ => ‘2048’,
‘jpeg_quality’ => ‘60’,
‘overwriteprotocol’ => ‘https’,
‘maintenance’ => false,
‘logfile’ => '/media/641bef0a-6fe9-4c6a-95d3-dd62da3eaca2/ncdata/nextcloud.lo$
‘loglevel’ => ‘2’,
‘log_type’ => ‘file’,
‘theme’ => ‘’,
‘default_phone_region’ => ‘DE’,
