Epubviewer :: where to submit issues?
    • Nextcloud Hub 25 Autumn (32.0.5)
    • Alma 9
    • Apache 2.4.62-7.el9_7.3
    • not used
    • 8.3.30
    • yes
    • not sure
    • bare metal
    • no
i have these errors in logs
{"reqId":"aXhz70h6keOijQbu6RQlAwAAANQ","level":3,"time":"2026-01-27T10:14:39+02:00","remoteAddr":"SANITIZED","user":"SANITIZED","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/omicu/","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Macintosh) mirall/4.0.6 (Nextcloud, macos-24.6.0 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.5.0","clientReqId":"f365ff05-cdce-467a-8da4-8442ffde64e8","exception":{"Exception":"OCA\\DAV\\Exception\\ServerMaintenanceMode","Message":"System is in maintenance mode.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkMaintenanceMode","class":"OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin","type":"->"},{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":211,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":424,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":22,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":151,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php","Line":65,"message":"Uncaught exception","exception":{},"CustomMessage":"Uncaught exception"}}
{"reqId":"aXhz80h6keOijQbu6RQlCAAAAMQ","level":3,"time":"2026-01-27T10:14:43+02:00","remoteAddr":"SANITIZED","user":"SANITIZED","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/omicu/","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Macintosh) mirall/4.0.6 (Nextcloud, macos-24.6.0 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.5.0","clientReqId":"9eb17ecc-476b-4942-834d-b3397a0824af","exception":{"Exception":"OCA\\DAV\\Exception\\ServerMaintenanceMode","Message":"System is in maintenance mode.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkMaintenanceMode","class":"OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin","type":"->"},{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":211,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":424,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":22,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":151,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php","Line":65,"message":"Uncaught exception","exception":{},"CustomMessage":"Uncaught exception"}}
{"reqId":"aXhz9Uh6keOijQbu6RQlDQAAAMI","level":3,"time":"2026-01-27T10:14:45+02:00","remoteAddr":"SANITIZED","user":"SANITIZED","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/vconstantinescu/","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.4 (build 20251215) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.5.0","clientReqId":"06171148-d168-420e-8626-d44bf5470f02","exception":{"Exception":"OCA\\DAV\\Exception\\ServerMaintenanceMode","Message":"System is in maintenance mode.","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkMaintenanceMode","class":"OCA\\DAV\\Connector\\Sabre\\MaintenancePlugin","type":"->"},{"file":"/var/www/nextcloud/apps/epubviewer/vendor/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":211,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":424,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":22,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":151,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/MaintenancePlugin.php","Line":65,"message":"Uncaught exception","exception":{},"CustomMessage":"Uncaught exception"}}
  1. I do not know
see above
        "version": "32.0.5.0",
        "overwrite.cli.url": "https:\/\/isscloud.spacescience.ro",
            "localhost",
            "isscloud.spacescience.ro",
            "46.243.114.245"
        "htaccess.RewriteBase": "\/",
        "dbtype": "mysql",
        "dbport": "",
        "mysql.utf8mb4": true,
        "default_language": "en",
        "default_locale": "ro",
        "default_phone_region": "RO",
        "default_timezone": "Europe\/Bucharest",
        "trashbin_retention_obligation": "30,90",
        "log_type": "file",
        "logfile": "\/var\/log\/nextcloud.log",
        "logfile_audit": "\/var\/log\/nextcloud_audit.log",
        "loglevel": 3,
        "loglevel_frontend": 2,
        "logtimezone": "Europe\/Bucharest",
        "defaultapp": "dashboard,files",
        "enable_previews": false,
        "redis": {
            "port": 6379,
            "timeout": 0,
            "read_timeout": 0,
            "user": "",
            "dbindex": 0
        "sharing.enable_mail_link_password_expiration": false,
        "sharing.mail_link_password_expiration_interval": 3600,
        "tempdirectory": "\/nextcloud\/tmp",
        "updatedirectory": "\/nextcloud\/update",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "app_install_overwrite": [],
        "theme": "",
        "trusted_proxies": "***REMOVED SENSITIVE VALUE***"
  - activity: 5.0.0-dev.0
  - admin_audit: 1.22.0
  - announcementbanner: 2.0.0
  - announcementcenter: 7.3.0
  - approval: 2.7.1
  - bookmarks: 16.0.1
  - calendar: 6.1.5
  - calendar_resource_management: 0.11.0
  - circles: 32.0.0
  - comments: 1.22.0
  - contacts: 8.3.1
  - contactsinteraction: 1.13.1
  - dashboard: 7.12.0
  - dav: 1.34.2
  - deck: 1.16.3
  - drawio: 3.1.2
  - epubviewer: 1.8.1
  - event_update_notification: 2.8.0
  - external: 7.0.0
  - files: 2.4.0
  - files_accesscontrol: 3.0.2
  - files_archive: 1.2.8
  - files_automatedtagging: 3.0.3
  - files_external: 1.24.1
  - files_lock: 32.0.1
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - files_zip: 2.2.0
  - firstrunwizard: 5.0.0-dev.0
  - flow_notifications: 3.0.0
  - forms: 5.2.4
  - fulltextsearch: 32.0.0
  - group_default_quota: 0.1.13
  - groupfolders: 20.1.9
  - groupquota: 0.2.3
  - integration_github: 3.2.2
  - integration_gitlab: 4.0.0
  - intros: 1.2.1
  - logcleaner: 1.2.6
  - logreader: 5.0.0-dev.0
  - mail: 5.6.8
  - notes: 4.12.4
  - notifications: 5.0.0-dev.0
  - notify_push: 1.3.0
  - oauth2: 1.20.0
  - ownershiptransfer: 1.3.0
  - passwords: 2025.12.21
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - quota_warning: 1.23.0
  - registration: 2.8.0
  - richdocuments: 9.0.2
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - sharereview: 2.1.0
  - spreed: 22.0.8
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - tables: 1.0.3
  - tasks: 0.17.1
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - user_usage_report: 3.0.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - workflow_script: 3.0.0
  - workflowengine: 2.14.0
  - app_api: 32.0.0 (installed 32.0.0)
  - checksum: 2.0.3 (installed 2.0.3)
  - encryption: 2.20.0
  - federation: 1.22.0 (installed 1.20.0)
  - integration_dropbox: 4.1.0 (installed 4.1.0)
  - integration_mattermost: 2.1.1 (installed 2.1.1)
  - libresign: 12.1.0 (installed 12.1.0)
  - metadata: 0.23.0 (installed 0.23.0)
  - onlyoffice: 9.12.0 (installed 9.12.0)
  - related_resources: 3.0.0-dev.0 (installed 1.5.0)
  - sociallogin: 6.3.0 (installed 6.3.0)
  - twofactor_nextcloud_notification: 6.0.0-dev.0 (installed 6.0.0-dev.0)
  - user_ldap: 1.23.0
  - whiteboard: 1.5.3 (installed 1.5.3)
and the reason i ask is that the git repository https://github.com/devnoname120/epubviewer lacks Issues category
Hey @adriansev welcome back :waving_hand:
you could try direct contact devnoname120 (Paul) · GitHub
For future reference, just check the app page in the app store (Either from within the web UI or by visiting https://apps.nextcloud.com/). There’s always a “Report problem” / etc link for the app in question.
For further reference, before writing, make sure that your answer works .. of course i went to “Report problem“, that is a link to the git repository that do not have an “Issue“ category (hence i could not fill a bug/issue report).
Thank you!
Please contact devnoname120 (Paul) · GitHub via E-Mail and ask wether if he just forgot to enable the issues section for the repository.
yup, mail already sent with brief information of the problem and a link to this topic. when i will get an answer i will ask also about the missing Issues category.
I would post it in the “Discussions” section. But as always with community FOSS projects, there is no guarantee that anyone will fix issues, support you, or even respond at all.
Btw, there is this post by the maintainer: https://github.com/devnoname120/epubviewer/discussions/18
Thanks a lot!! This actually solves my issue, as i can just remove this extension given this status.
It is still supported. The last update was in October 2025 to support Nextcloud 32: 1.8.1 · devnoname120/epubviewer · Discussion #36 · GitHub
