Nextcloud version (eg, 20.0.5): replace me
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
I set up a fresh install of a test-instance of Nextcloud. I followed this steps for encryption: Using the occ command — Nextcloud latest Administration Manual latest documentation
I enabled maintenace mode as written: “You must first put your Nextcloud server into maintenance mode”
But when I use the “encryption:encrypt-all” command, I get the error:
In Manager.php line 199:
Default encryption module not loaded
But the default encryption mode is set. If I don’t enable maintenance mode, it works and it is encrypting.
- do not enable maintenance mode and it works
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'xxx',
'datadirectory' => '/home/users/xxx/www/nextcloud/data',
'version' => '28.0.1.1',
'overwrite.cli.url' => 'xx',
'dbname' => 'xxx',
'dbhost' => 'localhost',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
