'Enable LDAP password changes per user' on OpenLDAP/PPolicy does not work
    • 31.0.9
    • debian bookworm
    • Apache
    • bookworm standard (8.2.29-1~deb12u1)
I’ve enabled on my OpenLDAP backend PPolicy and (try to) enable Nextcloud password change; whenever i try to enable it (with LDSAP administrator bind or with anonyìmous bind, does not change) i face this error:
{"reqId":"GOVRfvZfkn5vYcIzvxwc","level":3,"time":"2026-01-03T17:15:06+01:00","remoteAddr":"192.168.1.254","user":"gaio","app":"index","method":"POST","url":"/index.php/login","message":"array_key_exists(): Argument #2 ($array) must be of type array, null given in file '/var/www/nextcloud/apps/user_ldap/lib/User/User.php' line 744","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"31.0.9.1","exception":{"Exception":"Exception","Message":"array_key_exists(): Argument #2 ($array) must be of type array, null given in file '/var/www/nextcloud/apps/user_ldap/lib/User/User.php' line 744","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":161,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1063,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":24,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":146,"Previous":{"Exception":"TypeError","Message":"array_key_exists(): Argument #2 ($array) must be of type array, null given","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","line":744,"function":"array_key_exists"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Hook.php","line":85,"function":"handlePasswordExpiry","class":"OCA\\User_LDAP\\User\\User","type":"->"},{"file":"/var/www/nextcloud/lib/private/Server.php","line":525,"function":"emit","class":"OC_Hook","type":"::"},{"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Hooks/EmitterTrait.php","line":88,"function":"call_user_func_array"},{"file":"/var/www/nextcloud/lib/private/Hooks/PublicEmitter.php","line":22,"function":"emit","class":"OC\\Hooks\\BasicEmitter","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":350,"function":"emit","class":"OC\\Hooks\\PublicEmitter","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/CompleteLoginCommand.php","line":22,"function":"completeLogin","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":22,"function":"process","class":"OC\\Authentication\\Login\\CompleteLoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/LoggedInCheckCommand.php","line":41,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":22,"function":"process","class":"OC\\Authentication\\Login\\LoggedInCheckCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/EmailLoginCommand.php","line":51,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":22,"function":"process","class":"OC\\Authentication\\Login\\EmailLoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php","line":36,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":22,"function":"process","class":"OC\\Authentication\\Login\\UidLoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php","line":39,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":22,"function":"process","class":"OC\\Authentication\\Login\\UserDisabledCheckCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php","line":34,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->"},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/Chain.php","line":45,"function":"process","class":"OC\\Authentication\\Login\\PreLoginHookCommand","type":"->"},{"file":"/var/www/nextcloud/core/Controller/LoginController.php","line":344,"function":"process","class":"OC\\Authentication\\Login\\Chain","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":200,"function":"tryLogin","class":"OC\\Core\\Controller\\LoginController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":114,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":161,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1063,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":24,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/user_ldap/lib/User/User.php","Line":744},"message":"array_key_exists(): Argument #2 ($array) must be of type array, null given in file '/var/www/nextcloud/apps/user_ldap/lib/User/User.php' line 744","exception":{},"CustomMessage":"array_key_exists(): Argument #2 ($array) must be of type array, null given in file '/var/www/nextcloud/apps/user_ldap/lib/User/User.php' line 744"}}
If i disable it, things get back on work instantly.
I’ve tried to lookup this error on this forum and on google, but nothing relevant popups.
What i’m missing? Thanks.
I believe this was fixed in >=v32, but I don’t see a backport of the bug fix to v31.
I’ll trigger a backport now to get it into upcoming v31 maintenance release.
