I’ve checked the Uncomplicated Firewall in Ubuntu and ports 80 and 443 are allowed.
I ran the iptables -L and the results are below. I also ran tcpdump -n port 22
Unfortunately it’s all Greek to me. Can someone have a look at advise if I’m any closer to finding where I’m getting blocked?
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all – anywhere anywhere
ufw-before-input all – anywhere anywhere
ufw-after-input all – anywhere anywhere
ufw-after-logging-input all – anywhere anywhere
ufw-reject-input all – anywhere anywhere
ufw-track-input all – anywhere anywhere
Chain FORWARD (policy DROP)
ufw-before-logging-forward all – anywhere anywhere
ufw-before-forward all – anywhere anywhere
ufw-after-forward all – anywhere anywhere
ufw-after-logging-forward all – anywhere anywhere
ufw-reject-forward all – anywhere anywhere
ufw-track-forward all – anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all – anywhere anywhere
ufw-before-output all – anywhere anywhere
ufw-after-output all – anywhere anywhere
ufw-after-logging-output all – anywhere anywhere
ufw-reject-output all – anywhere anywhere
ufw-track-output all – anywhere anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp – anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp – anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp – anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all – anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all – anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT all – anywhere anywhere ctstate RELATED,ESTABLISHED
ACCEPT icmp – anywhere anywhere icmp destination-unreachable
ACCEPT icmp – anywhere anywhere icmp time-exceeded
ACCEPT icmp – anywhere anywhere icmp parameter-problem
ACCEPT icmp – anywhere anywhere icmp echo-request
ufw-user-forward all – anywhere anywhere
Chain ufw-before-input (1 references)
ufw-logging-deny all – anywhere anywhere ctstate INVALID
DROP all – anywhere anywhere ctstate INVALID
ACCEPT udp – anywhere anywhere udp spt:bootps dpt:bootpc
ufw-not-local all – anywhere anywhere
ACCEPT udp – anywhere 224.0.0.251 udp dpt:mdns
ACCEPT udp – anywhere 239.255.255.250 udp dpt:1900
ufw-user-input all – anywhere anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all – anywhere anywhere
Chain ufw-logging-allow (0 references)
LOG all – anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all – anywhere anywhere ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all – anywhere anywhere ADDRTYPE match dst-type LOCAL
RETURN all – anywhere anywhere ADDRTYPE match dst-type MULTICAST
RETURN all – anywhere anywhere ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all – anywhere anywhere limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp – anywhere anywhere ctstate NEW
ACCEPT udp – anywhere anywhere ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp – anywhere anywhere tcp dpt:https
ACCEPT udp – anywhere anywhere udp dpt:https
ACCEPT tcp – anywhere anywhere multiport dports http,https
ACCEPT udp – anywhere anywhere udp dpt:80
Chain ufw-user-limit (0 references)
LOG all – anywhere anywhere limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT all – anywhere anywhere reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
11:19:41.397514 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [P.], seq 351:436, ack 486, win 3888, options [nop,nop,TS val 241160 ecr 3661899956], length 85: HTTP
11:19:41.397541 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [.], ack 436, win 501, options [nop,nop,TS val 3661899966 ecr 241160], length 0
11:19:41.410296 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 32640:33130, ack 56212, win 2916, options [nop,nop,TS val 3661899978 ecr 241160], length 490: HTTP: GET /api/monitoring/traffic-statistics HTTP/1.1
11:19:41.411311 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [P.], seq 486:963, ack 436, win 501, options [nop,nop,TS val 3661899979 ecr 241160], length 477: HTTP: GET /api/net/current-plmn HTTP/1.1
11:19:41.424994 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 56212:56563, ack 33130, win 18628, options [nop,nop,TS val 241163 ecr 3661899978], length 351: HTTP: HTTP/1.1 200 OK
11:19:41.424994 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 56563:56996, ack 33130, win 18628, options [nop,nop,TS val 241163 ecr 3661899978], length 433: HTTP
11:19:41.425175 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 56996, win 2950, options [nop,nop,TS val 3661899993 ecr 241163], length 0
11:19:41.442409 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [.], ack 963, win 4156, options [nop,nop,TS val 241165 ecr 3661899979], length 0
11:19:41.497663 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [P.], seq 436:787, ack 963, win 4156, options [nop,nop,TS val 241170 ecr 3661899979], length 351: HTTP: HTTP/1.1 200 OK
11:19:41.497727 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [P.], seq 787:966, ack 963, win 4156, options [nop,nop,TS val 241170 ecr 3661899979], length 179: HTTP
11:19:41.497885 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [.], ack 966, win 501, options [nop,nop,TS val 3661900066 ecr 241170], length 0
11:19:44.335931 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 33130:33608, ack 56996, win 2950, options [nop,nop,TS val 3661902904 ecr 241163], length 478: HTTP: GET /api/monitoring/status HTTP/1.1
11:19:44.336495 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [P.], seq 963:1442, ack 966, win 501, options [nop,nop,TS val 3661902904 ecr 241170], length 479: HTTP: GET /api/cradle/status-info HTTP/1.1
11:19:44.336909 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [.], ack 1442, win 4424, options [nop,nop,TS val 241454 ecr 3661902904], length 0
11:19:44.366230 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [P.], seq 966:1317, ack 1442, win 4424, options [nop,nop,TS val 241457 ecr 3661902904], length 351: HTTP: HTTP/1.1 200 OK
11:19:44.366230 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [P.], seq 1317:1641, ack 1442, win 4424, options [nop,nop,TS val 241457 ecr 3661902904], length 324: HTTP
11:19:44.366444 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [.], ack 1641, win 501, options [nop,nop,TS val 3661902934 ecr 241457], length 0
11:19:44.366500 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 56996:57348, ack 33608, win 18628, options [nop,nop,TS val 241457 ecr 3661902904], length 352: HTTP: HTTP/1.1 200 OK
11:19:44.366567 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 57348:58437, ack 33608, win 18628, options [nop,nop,TS val 241457 ecr 3661902904], length 1089: HTTP
11:19:44.366593 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 58437, win 2990, options [nop,nop,TS val 3661902935 ecr 241457], length 0
11:19:44.382229 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 33608:34099, ack 58437, win 2990, options [nop,nop,TS val 3661902950 ecr 241457], length 491: HTTP: GET /api/monitoring/check-notifications HTTP/1.1
11:19:44.384211 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [F.], seq 1641, ack 1442, win 4424, options [nop,nop,TS val 241459 ecr 3661902934], length 0
11:19:44.384492 IP 192.168.8.100.52594 > 192.168.8.1.80: Flags [F.], seq 1442, ack 1642, win 501, options [nop,nop,TS val 3661902952 ecr 241459], length 0
11:19:44.384971 IP 192.168.8.1.80 > 192.168.8.100.52594: Flags [.], ack 1443, win 4424, options [nop,nop,TS val 241459 ecr 3661902952], length 0
11:19:44.392484 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 58437:58788, ack 34099, win 18628, options [nop,nop,TS val 241460 ecr 3661902950], length 351: HTTP: HTTP/1.1 200 OK
11:19:44.392484 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 58788:58968, ack 34099, win 18628, options [nop,nop,TS val 241460 ecr 3661902950], length 180: HTTP
11:19:44.392709 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 58968, win 3024, options [nop,nop,TS val 3661902961 ecr 241460], length 0
11:19:44.405301 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 34099:34589, ack 58968, win 3024, options [nop,nop,TS val 3661902973 ecr 241460], length 490: HTTP: GET /api/monitoring/traffic-statistics HTTP/1.1
11:19:44.410935 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [S], seq 3150501751, win 64240, options [mss 1460,sackOK,TS val 3661902979 ecr 0,nop,wscale 7], length 0
11:19:44.411413 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [S.], seq 3242495773, ack 3150501752, win 14480, options [mss 1460,sackOK,TS val 241461 ecr 3661902979,nop,wscale 2], length 0
11:19:44.411502 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [.], ack 1, win 502, options [nop,nop,TS val 3661902979 ecr 241461], length 0
11:19:44.411805 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [P.], seq 1:486, ack 1, win 502, options [nop,nop,TS val 3661902980 ecr 241461], length 485: HTTP: GET /api/dialup/mobile-dataswitch HTTP/1.1
11:19:44.412312 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [.], ack 486, win 3888, options [nop,nop,TS val 241462 ecr 3661902980], length 0
11:19:44.422499 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 58968:59319, ack 34589, win 18628, options [nop,nop,TS val 241463 ecr 3661902973], length 351: HTTP: HTTP/1.1 200 OK
11:19:44.422499 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 59319:59752, ack 34589, win 18628, options [nop,nop,TS val 241463 ecr 3661902973], length 433: HTTP
11:19:44.422617 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 59752, win 3058, options [nop,nop,TS val 3661902991 ecr 241463], length 0
11:19:44.422752 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [P.], seq 1:351, ack 486, win 3888, options [nop,nop,TS val 241463 ecr 3661902980], length 350: HTTP: HTTP/1.1 200 OK
11:19:44.422792 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [.], ack 351, win 501, options [nop,nop,TS val 3661902991 ecr 241463], length 0
11:19:44.422812 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [P.], seq 351:436, ack 486, win 3888, options [nop,nop,TS val 241463 ecr 3661902980], length 85: HTTP
11:19:44.422824 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [.], ack 436, win 501, options [nop,nop,TS val 3661902991 ecr 241463], length 0
11:19:44.431350 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 34589:35079, ack 59752, win 3058, options [nop,nop,TS val 3661902999 ecr 241463], length 490: HTTP: GET /api/monitoring/traffic-statistics HTTP/1.1
11:19:44.432993 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [P.], seq 486:963, ack 436, win 501, options [nop,nop,TS val 3661903001 ecr 241463], length 477: HTTP: GET /api/net/current-plmn HTTP/1.1
11:19:44.442538 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 59752:60103, ack 35079, win 18628, options [nop,nop,TS val 241465 ecr 3661902999], length 351: HTTP: HTTP/1.1 200 OK
11:19:44.442538 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 60103:60536, ack 35079, win 18628, options [nop,nop,TS val 241465 ecr 3661902999], length 433: HTTP
11:19:44.442693 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 60536, win 3092, options [nop,nop,TS val 3661903011 ecr 241465], length 0
11:19:44.472201 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [.], ack 963, win 4156, options [nop,nop,TS val 241468 ecr 3661903001], length 0
11:19:44.519222 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [P.], seq 436:787, ack 963, win 4156, options [nop,nop,TS val 241472 ecr 3661903001], length 351: HTTP: HTTP/1.1 200 OK
11:19:44.519285 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [P.], seq 787:966, ack 963, win 4156, options [nop,nop,TS val 241472 ecr 3661903001], length 179: HTTP
11:19:44.519439 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [.], ack 966, win 501, options [nop,nop,TS val 3661903087 ecr 241472], length 0
11:19:47.333447 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 35079:35567, ack 60536, win 3092, options [nop,nop,TS val 3661905901 ecr 241465], length 488: HTTP: GET /api/monitoring/converged-status HTTP/1.1
11:19:47.335586 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [F.], seq 966, ack 963, win 4156, options [nop,nop,TS val 241754 ecr 3661903087], length 0
11:19:47.335879 IP 192.168.8.100.37338 > 192.168.8.1.80: Flags [F.], seq 963, ack 967, win 501, options [nop,nop,TS val 3661905904 ecr 241754], length 0
11:19:47.336597 IP 192.168.8.1.80 > 192.168.8.100.37338: Flags [.], ack 964, win 4156, options [nop,nop,TS val 241754 ecr 3661905904], length 0
11:19:47.372589 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [.], ack 35567, win 18628, options [nop,nop,TS val 241758 ecr 3661905901], length 0
11:19:47.450814 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 60536:60887, ack 35567, win 18628, options [nop,nop,TS val 241765 ecr 3661905901], length 351: HTTP: HTTP/1.1 200 OK
11:19:47.450814 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 60887:61054, ack 35567, win 18628, options [nop,nop,TS val 241765 ecr 3661905901], length 167: HTTP
11:19:47.451046 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 61054, win 3126, options [nop,nop,TS val 3661906019 ecr 241765], length 0
11:19:48.331021 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 35567:36045, ack 61054, win 3126, options [nop,nop,TS val 3661906899 ecr 241765], length 478: HTTP: GET /api/monitoring/status HTTP/1.1
11:19:48.331508 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [.], ack 36045, win 18628, options [nop,nop,TS val 241853 ecr 3661906899], length 0
11:19:48.332618 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [S], seq 3214769166, win 64240, options [mss 1460,sackOK,TS val 3661906901 ecr 0,nop,wscale 7], length 0
11:19:48.333146 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [S.], seq 2159539421, ack 3214769167, win 14480, options [mss 1460,sackOK,TS val 241853 ecr 3661906901,nop,wscale 2], length 0
11:19:48.333178 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [.], ack 1, win 502, options [nop,nop,TS val 3661906901 ecr 241853], length 0
11:19:48.333314 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [P.], seq 1:480, ack 1, win 502, options [nop,nop,TS val 3661906901 ecr 241853], length 479: HTTP: GET /api/cradle/status-info HTTP/1.1
11:19:48.334014 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [.], ack 480, win 3888, options [nop,nop,TS val 241853 ecr 3661906901], length 0
11:19:48.360048 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 1:352, ack 480, win 3888, options [nop,nop,TS val 241856 ecr 3661906901], length 351: HTTP: HTTP/1.1 200 OK
11:19:48.360095 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [.], ack 352, win 501, options [nop,nop,TS val 3661906928 ecr 241856], length 0
11:19:48.360048 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 352:676, ack 480, win 3888, options [nop,nop,TS val 241856 ecr 3661906901], length 324: HTTP
11:19:48.360111 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [.], ack 676, win 499, options [nop,nop,TS val 3661906928 ecr 241856], length 0
11:19:48.360137 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 61054:61406, ack 36045, win 18628, options [nop,nop,TS val 241856 ecr 3661906899], length 352: HTTP: HTTP/1.1 200 OK
11:19:48.360257 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 61406:62495, ack 36045, win 18628, options [nop,nop,TS val 241856 ecr 3661906899], length 1089: HTTP
11:19:48.360283 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 62495, win 3166, options [nop,nop,TS val 3661906928 ecr 241856], length 0
11:19:48.367386 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 36045:36536, ack 62495, win 3166, options [nop,nop,TS val 3661906935 ecr 241856], length 491: HTTP: GET /api/monitoring/check-notifications HTTP/1.1
11:19:48.372688 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 62495:62846, ack 36536, win 18628, options [nop,nop,TS val 241858 ecr 3661906935], length 351: HTTP: HTTP/1.1 200 OK
11:19:48.372688 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 62846:63026, ack 36536, win 18628, options [nop,nop,TS val 241858 ecr 3661906935], length 180: HTTP
11:19:48.372801 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 63026, win 3200, options [nop,nop,TS val 3661906941 ecr 241858], length 0
11:19:48.376390 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 36536:37026, ack 63026, win 3200, options [nop,nop,TS val 3661906944 ecr 241858], length 490: HTTP: GET /api/monitoring/traffic-statistics HTTP/1.1
11:19:48.377805 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [P.], seq 480:965, ack 676, win 501, options [nop,nop,TS val 3661906946 ecr 241856], length 485: HTTP: GET /api/dialup/mobile-dataswitch HTTP/1.1
11:19:48.381609 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 63026:63377, ack 37026, win 18628, options [nop,nop,TS val 241858 ecr 3661906944], length 351: HTTP: HTTP/1.1 200 OK
11:19:48.381687 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 63377:63810, ack 37026, win 18628, options [nop,nop,TS val 241858 ecr 3661906944], length 433: HTTP
11:19:48.381789 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 63810, win 3234, options [nop,nop,TS val 3661906950 ecr 241858], length 0
11:19:48.390344 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 676:1026, ack 965, win 4156, options [nop,nop,TS val 241859 ecr 3661906946], length 350: HTTP: HTTP/1.1 200 OK
11:19:48.390345 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 1026:1111, ack 965, win 4156, options [nop,nop,TS val 241859 ecr 3661906946], length 85: HTTP
11:19:48.390592 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [.], ack 1111, win 501, options [nop,nop,TS val 3661906959 ecr 241859], length 0
11:19:48.400990 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [P.], seq 37026:37516, ack 63810, win 3234, options [nop,nop,TS val 3661906969 ecr 241858], length 490: HTTP: GET /api/monitoring/traffic-statistics HTTP/1.1
11:19:48.402547 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [P.], seq 965:1442, ack 1111, win 501, options [nop,nop,TS val 3661906971 ecr 241859], length 477: HTTP: GET /api/net/current-plmn HTTP/1.1
11:19:48.410419 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 63810:64161, ack 37516, win 18628, options [nop,nop,TS val 241861 ecr 3661906969], length 351: HTTP: HTTP/1.1 200 OK
11:19:48.410419 IP 192.168.8.1.80 > 192.168.8.100.43694: Flags [P.], seq 64161:64594, ack 37516, win 18628, options [nop,nop,TS val 241861 ecr 3661906969], length 433: HTTP
11:19:48.410623 IP 192.168.8.100.43694 > 192.168.8.1.80: Flags [.], ack 64594, win 3268, options [nop,nop,TS val 3661906979 ecr 241861], length 0
11:19:48.442552 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [.], ack 1442, win 4424, options [nop,nop,TS val 241865 ecr 3661906971], length 0
11:19:48.491148 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 1111:1462, ack 1442, win 4424, options [nop,nop,TS val 241869 ecr 3661906971], length 351: HTTP: HTTP/1.1 200 OK
11:19:48.491148 IP 192.168.8.1.80 > 192.168.8.100.37352: Flags [P.], seq 1462:1641, ack 1442, win 4424, options [nop,nop,TS val 241869 ecr 3661906971], length 179: HTTP
11:19:48.491422 IP 192.168.8.100.37352 > 192.168.8.1.80: Flags [.], ack 1641, win 501, options [nop,nop,TS val 3661907059 ecr 241869], length 0
