example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.0.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.1 LTS
Apache or nginx version (eg, Apache 2.4.25): 2.4.41
PHP version (eg, 7.4): 7.3.28
I want to embed my nextcloud installation in a trusted iFrame on another domain of mine. While basic embedding works by editting the $allowedFrameAncestors variable in the ContentSecurityPolicy.php file, I just get a login screen presented. It does do a server request / loading icon for a bit but then just refreshes the page back to the login page. Presumably this is caused by cookies not being handled well over/within the iframe.
Most if not all hits you get searching on this are about security headers not including the domain you want to embed from. But that isn’t the issue as I get the Nextcloud login screen. I just would like to be able to actually login or use some kind of single sign on so I can for example share a Deck board.
Is this the first time you’ve seen this error? (N):
<iframe width='1000' height='600' frameborder='0' src='https://a.com/index.php/s/HX3tJJm3d2yneiW'></iframe>
Make sure domain b.com is added to the $allowedFrameAncestors array in /lib/public/AppFramework/Http/ContentSecurityPolicy.php
Try to view the page (should succeed) and login using existing credentials (should fail).
none
'instanceid' => '518439h4893f3jf28db',
'passwordsalt' => 'blablablablabla',
'datadirectory' => '/yoda/cloudstore/data/',
'version' => '22.0.0.11',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'blablabalbalbalbla',
'overwritewebroot' => '/',
'forcessl' => true,
'trashbin_retention_obligation' => 'auto,90',
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'theme' => '',
'default_phone_region' => 'NL',
'has_internet_connection' => true,
'check_for_working_webdav' => true,
'check_for_working_htaccess' => true,
'redis' =>
'port' => 0,
'timeout' => 0,
'dbindex' => 0,
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '::1',
2 => '192.168.100.6',
3 => 'a.com',
0 => 'a.com',
1 => 'b.com',
2 => 'collabora.a.com',
'mail_from_address' => 'fromMe',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'a.com',
'secret' => 'whowthisissecret7',
'asset-pipeline.enabled' => true,
'preview_max_scale_factor' => 1,
'forceSSLforSubdomains' => true,
'app.mail.imaplog.enabled' => true,
'loglevel' => 2,
'log_type' => 'file',
'appstore.experimental.enabled' => true,
'overwrite.cli.url' => 'https://a.com',
'mail_smtphost' => 'localhost',
'mail_smtpport' => '25',
'data-fingerprint' => 'ncjdsncjkdsnckjndk',
'updater.release.channel' => 'beta',
'twofactor_enforced' => 'false',
'app_install_overwrite' =>
0 => 'keeweb',
'app.mail.verify-tls-peer' => false,
'updater.secret' => 'looksSecret10183',
can;t see any relevant logging...
