I am Using Moodle 4.5, Mahara and a number of other applications where it would be really great if I could share documents with students, colleagues etc. actually as the documents are rather than as bland links.
In Onedrive, you can generate an iframe link which allows you to achieve this, so how cool would it be if Nextcloud could do the same. Click on the iframe generate button, and bingo, copy and paste into whichever application you want your documents to appear in.
