Hello everyone,
I am using NC 10.0.2 as of now (still waiting for the update-available message in the cloud software) and installed in on a Pi 3 using the official manual “Installation on Linux” from the website. The problem I encounter is that I (or any other user) do not receive any notification emails from Nextcloud although all of us entered a valid email address in the personal settings.
Checking in with the admin account and going to the logging section I see that there seems to be an error occuring with the automatic email notification service. However I have no idea at all what this message is supposed to mean, so maybe anyone can help me out on this one?
Here is the error message in full-length:
Error while running background job (class: OCA\Activity\BackgroundJob\EmailNotification, arguments: ): {“Exception”:“Doctrine\DBAL\Exception\SyntaxErrorException”,“Message”:“An exception occurred while executing ‘DELETE FROM
oc_activity_mq
WHEREamq_timestamp
<= ? ANDamq_affecteduser
IN ()’ with params [1483210278]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘)’ at line 1”,“Code”:0,“Trace”:"#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(116): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException(‘An exception oc…’, Object(Doctrine\DBAL\Driver\PDOException))\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Statement.php(175): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), ‘DELETE FROM `oc…’, Array)\n#2 /var/www/nextcloud/apps/activity/lib/MailQueueHandler.php(293): Doctrine\DBAL\Statement->execute(Array)\n#3 /var/www/nextcloud/apps/activity/lib/BackgroundJob/EmailNotification.php(145): OCA\Activity\MailQueueHandler->deleteSentItems(Array, 1483210278)\n#4 /var/www/nextcloud/apps/activity/lib/BackgroundJob/EmailNotification.php(99): OCA\Activity\BackgroundJob\EmailNotification->runStep(25, 1483210278)\n#5 /var/www/nextcloud/lib/private/BackgroundJob/Job.php(53): OCA\Activity\BackgroundJob\EmailNotification->run(NULL)\n#6 /var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php(54): OC\BackgroundJob\Job->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))\n#7 /var/www/nextcloud/cron.php(145): OC\BackgroundJob\TimedJob->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))\n#8 {main}",“File”:"/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php",“Line”:90} <
