Hi
I’m actually runing a preconfigured vm.
Is there an easy way to know the modules/components running the nextcloud instance such as Web server, DB make, NC release, PHP, maybe something else?
Appreciate your help
thx markus
Hi
thx markus
Without login for all nextclouds with “status.php”:
https://demo1.nextcloud.com/status.php
If you are logged in (admin) there is
https://cloud.server.tld/settings/admin/serverinfo
Also there is an API (admin login):
https://cloud.server.tld/ocs/v2.php/apps/serverinfo/api/v1/info
thx devnul
easy
