Domain check failing for nextcloud-aio behind nginx reverse-proxy with compose
I am trying to deploy nextcloud-aio behind reverse-proxy (nginx) using docker compose on my VPS.
Since I am using docker compose, nginx is running in its own docker network.
Therefore, following the documentation, I added APACHE_ADDITIONAL_NETWORK env to my nextcloud service and adjusted nginx config with http://nextcloud-aio-apache:$APACHE_PORT.
In the AIO interface, the domain check fails (error: “Domain does not point to this server or the reverse proxy is not configured correctly. See the mastercontainer logs for more details. (‘sudo docker logs -f nextcloud-aio-mastercontainer’)”).
Logs from the nextcloud-aio-mastercontainer don’t give much information (to my understanding):
nextcloud-aio-mastercontainer  | NOTICE: PHP message: The response of the connection attempt to "https://mydomain</html>nter>nginx/1.28.0</center>/center>d>
nextcloud-aio-mastercontainer  | NOTICE: PHP message: Expected was: be563f44aa170befecb6d2253d69121d6b9d490a0a63e110
nextcloud-aio-mastercontainer  | NOTICE: PHP message: The error message was:
nextcloud-aio-mastercontainer  | NOTICE: PHP message: Please follow https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md#6-how-to-debug-things in order to debug things!
But I also have this in the nginx container logs:
nginx-1  | 2025/08/04 09:27:07 [error] 20#20: *39 no resolver defined to resolve nextcloud-aio-apache, client: 172.18.0.1, server: mydomain.com, request: "GET / HTTP/2.0", host: "mydomain.com"
nginx-1  | 172.18.0.1 - - [04/Aug/2025:09:27:07 +0000] "GET / HTTP/2.0" 502 157 "-" "-" "-"
Running through the debugging steps, when checking if reverse proxy container manages to reach apache port, I have this result (but I am not sure what to conclude from it):
# From within nginx container
nc -z localhost 11000; echo $?  # Returns 1
nc -z <host IP> 11000; echo $?  # Returns 0
I tried to add port 11000 to the nginx service in compose, I obtained the same result.
Here is my compose.yaml file (I removed certbot stuff and other nginx volumes, which are not related to my error I think):
services:
  nginx:
    image: nginx:1.28-alpine
    ports:
      - 80:80
      - 443:443
    restart: always
    volumes:
      - /home/tvoirand/tvoirand/webserver_tvoirand/webserver_tvoirand/conf.d:/etc/nginx/conf.d:ro
  nextcloud:
    image: nextcloud/all-in-one:20250325_084656
    init: true
    restart: always
    volumes:
    ports:
      - 8080:8080
    environment:
      APACHE_IP_BINDING: 0.0.0.0
      APACHE_ADDITIONAL_NETWORK: webserver_tvoirand_default
I am not sure how to fix my issue. I suspect that it is related to docker networks. Should I use the default bridge network, adding network_mode: bridge to my services in compose? I would prefer keeping nextcloud and the reverse-proxy in a dedicated network, to isolate this stack from other stuff on my host.
Many thanks in advance for you help!
Here is also my nginx configuration file.
The modifications I applied to the default file from documentation:
  • Replace “your-nc-domain”
  • Replace “127.0.0.1” with “nextcloud-aio-apache” in proxy_pass directive
  • Adjust stuff related to nginx version (1.28.0 in my case)
map $http_upgrade $connection_upgrade {
    default upgrade;
    '' close;
server {
    listen 80;
    listen [::]:80;
    if ($scheme = "http") {
    if ($http_x_forwarded_proto = "http") {
    listen 443 ssl;
    listen [::]:443 ssl;
    http2 on;
    proxy_buffering off;
    proxy_request_buffering off;
    client_max_body_size 0;
    client_body_buffer_size 512k;
    # http3_stream_buffer_size 512k;
    proxy_read_timeout 86400s;
    server_name mydomain.com www.mydomain.com;
    location / {
        proxy_pass http://nextcloud-aio-apache:11000$request_uri;
        proxy_set_header X-Forwarded-Port $server_port;
        proxy_set_header X-Forwarded-Scheme $scheme;
        proxy_set_header Host $host;
        proxy_set_header Early-Data $ssl_early_data;
        # Websocket
        proxy_http_version 1.1;
        proxy_set_header Connection $connection_upgrade;
    ssl_certificate /etc/nginx/ssl/live/mydomain.com/fullchain.pem;
    ssl_certificate_key /etc/nginx/ssl/live/mydomain.com/privkey.pem;
    ssl_dhparam /etc/dhparam; # curl -L https://ssl-config.mozilla.org/ffdhe2048.txt -o /etc/dhparam
    ssl_early_data on;
    ssl_session_timeout 1d;
    ssl_session_cache shared:SSL:10m;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ecdh_curve x25519:x448:secp521r1:secp384r1:secp256r1;
    ssl_prefer_server_ciphers on;
    ssl_conf_command Options PrioritizeChaCha;
    ssl_ciphers TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256;
  • Nextcloud Server version:
    • Docker image nextcloud/all-in-one:20250325_084656
    • Ubuntu 24.04
  • Reverse proxy and version:
    • Nginx 1.28.0
  • Installation method:
    • AIO
I fixed my issue by adding resolver 127.0.0.11 ipv6=off; just before the proxy_pass directive in my nginx configuration file:
    location / {
I had also forgotten to specify the apache port for nextcloud in my compose file:
nextcloud:
  environment:
    APACHE_PORT: 11000
