if you guys would use the search-option here in the forum (e.g. with “rainbow”) there are some results…
the most promising one is (a bit older) Nextcloud box does not boot on rasberry pi
what i understood from it your problems could come from a broken sd-card. so if you have the opportunity to try it with a different sd?
and the original image? you will find it here --> https://download.nextcloud.com/server/images/
since the both of you got yourself a nextcloud box i think you could rely upon your power-supply which otherwise could be a reason for problems as well.
awww. and if you wouldn’t like the NC snap i suggest: try nextcloudpi. very easy set up as well and highly maintained
Thanx for the advice i managed to get the nextcloud 12 up and running with other sd card where i flashed the nextcloudpi image…
it works great on LAN but is there some simple manual how to set it up for external network?
I want to use it as regular web cloud
I would like to benefit from the nextclodpi user friendliness but I have no idea how to set it up… if i need server or something like that … meaning i need to buy a domain … or i can run it without it…
i have no clue what NAS means or SSHL or something …
Please can you help to understand what direction do I meed to focus my search for advice
i’d suggest to mark this thread as solved and - in case you’d need more help - to open a new one here in the forum under nextcloudpi or directly in the githubpage…
