I put some money on a bountysource for Owncloud (nextcloud didn’t exist at that time)
Allow Delta-Sync
Now this issue is closed and merged.
My question will this feature will also be present in NC 14 for exemple ?
Thank you
Allow Delta-Sync
Thank you
RE UP
Some news on owncloud
This feature was requested here in NC:
Currently ownCloud has merged the server part of the delta sync and they are still running tests with the sync client. It probably makes no sense to merge half reviewed code, it would be better to help testing and then backport these changes afterwards. For the status of the NC sync client, there is also this topic:
