Does anybody knows how to solve part of the warnings from Nextcloud while using Coolify?
Nextcloud version (eg, 26.0.1): replace me
Operating system and version (eg, Ubuntu 22.04): Operating System: Linux 6.8.0-41-generic x86_64
Apache or nginx version (eg, Apache 2.4.25): Nginx
PHP version (eg, 8.1): 8.3.10
Database (sqlite or MariaDB or Postgres) MySQL 8.4.2
Docker (compose) y
services:
  nextcloud:
    image: 'lscr.io/linuxserver/nextcloud:latest'
    environment:
      - SERVICE_FQDN_NEXTCLOUD
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Madrid
      - NEXTCLOUD_TRUSTED_DOMAINS=https://nextcloud.gdcmarinho.com
      - PHP_MEMORY_LIMIT=2048MB
      - PHP_UPLOAD_LIMIT=10000MB
      - REDIS_HOST=138.201.137.252
      - REDIS_PORT=5437
    volumes:
      - 'nextcloud-config:/config'
      - 'nextcloud-data:/data'
    healthcheck:
      test:
        - CMD
        - curl
        - '-f'
        - 'http://127.0.0.1:80'
      interval: 2s
      timeout: 10s
      retries: 15
Docker logs
root@Ubuntu-2404-noble-amd64-base ~ # docker logs nextcloud-e4kkw8k040k8c4008s0kgw8o
[migrations] started
[migrations] 01-nginx-site-confs-default: skipped
[migrations] 02-default-location: skipped
[migrations] done
   Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID:    1000
User GID:    1000
Linuxserver.io version: 29.0.7-ls342
Build-date: 2024-09-24T11:51:44+00:00
using keys found in /config/keys
Initializing nextcloud 29.0.7.1 (this can take a while) ...
Setting permissions
Initializing finished
[custom-init] No custom files found, skipping...
[ls.io-init] done.
Does anybody knows how to solve part of the warnings from Nextcloud while using Coolify? I mean, I do not have access to the configurations from the NGINX that I think Coolify uses underneath.
Btw, I’m using Nextcloud Hub 8 (29.0.7).
Please use the search function of the forum to find solutions for each of the listed errors, because they have definitely been discussed and solved, independently from the used environment/OS.
