- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
- 30.0.2
- Ubuntu 22.04.4 LTS
- nginx/1.18.0 (Ubuntu)
- PHP version (e.g, 8.3):
- PHP 8.1.2-1ubuntu2.19 (cli) (built: Sep 30 2024 16:25:25) (NTS)
- yah
- After installation
- Installation method (e.g. AIO, NCP, Bare Metal/Archive, etc.)
- Docker see below
- Are you using Cloudflare, mod_security, or similar? (Yes / No)
- No
- I can’t open or edit any document using nextcloud office. The error message is:
Document loading failed Failed to load Nextcloud Office - please try again later
I have followed this post here, and added WOPI 0.0.0.0/0 → did not work
So I looked up Admin settings → logging. I found:
Client error:POST https://monsoon.my-site.org:4443/cool/extract-document-structure?limit=content-control` resulted in a 403 Forbidden response`
- So I followed this post here (indeed my collabora is set to a different port) , but no change.
- Install NextCloud, using Docker.
version: '3.9'
services:
nextcloud:
image: nextcloud:latest
container_name: nextcloud
restart: always
ports:
- 8080:80
volumes:
- /var/docker/nextcloud/data:/var/www/html
- /var/docker/nextcloud/config:/var/www/html/config
depends_on:
- db
db:
image: mariadb
container_name: nextcloud_db
restart: always
environment:
MYSQL_ROOT_PASSWORD: secret pass
MYSQL_DATABASE: nextcloud
MYSQL_USER: nextcloud
MYSQL_PASSWORD: other secret pass
volumes:
- /var/docker/nextcloud/db:/var/lib/mysql
- Configure Nginx reverse proxy:
server {
listen 5021 ssl;
server_name monsoon.my-site.org;
ssl_certificate /etc/letsencrypt/live/monsoon.my-site.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/monsoon.my-site.org/privkey.pem; # managed by Certbot
location / {
proxy_pass http://127.0.0.1:8080/;
proxy_set_header Host $host;
server {
listen 80;
I can see the nextcloud install now.
- Set up collabora using docker:
version: '3.7'
services:
collabora:
image: collabora/code
container_name: collabora
restart: always
ports:
- "5022:9980"
environment:
- domain=monsoon.my-site.org
- "extra_params=--o:ssl.enable=false --o:ssl.termination=true"
volumes:
- /opt/collabora/data:/var/www/collabora/data
- /opt/collabora/loolwsd.xml:/etc/loolwsd/loolwsd.xml
- Configure nginx again:
server {
listen 4443 ssl;
server_name monsoon.my-site.org;# Self-signed SSL certificates ssl_certificate /etc/letsencrypt/live/monsoon.my-site.org/fullchain.pem; # managed by Certbot ssl_certificate_key /etc/letsencrypt/live/monsoon.my-site.org/privkey.pem; # managed by Certbot ssl_protocols TLSv1.2 TLSv1.3; ssl_ciphers HIGH:!aNULL:!MD5; # Proxy requests to the Collabora Docker container location / { proxy_pass http://localhost:5022; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto https; #proxy_set_header X-Forwarded-Proto $scheme; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-Port $server_port; proxy_set_header Forwarded "for=$remote_addr;proto=$scheme"; #proxy_buffering off; }client_max_body_size 0;
fastcgi_buffers 64 4K;# Disable buffering to prevent latency #proxy_request_buffering off;}
- Set instance of collabora to admin settings > office, with port # 4443. Then Restart everything
- Go back to the tab where nextcloud is open,. and then under apps > files > click on any odx document. (or even docx) - and the error is popping up.
{"reqId":"lywRjoeZcEGDexLp0usU","level":3,"time":"2024-11-29T10:03:00+00:00","remoteAddr":"79.117.107.52","user":"admin","app":"richdocuments","method":"GET","url":"/ocs/v2.php/apps/files/api/v1/templates","message":"Client error: `POST https://monsoon.my-site.org:4443/cool/extract-document-structure?limit=content-control` resulted in a `403 Forbidden` response","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:132.0) Gecko/20100101 Firefox/132.0","version":"30.0.2.2","data":{"app":"richdocuments"},"id":"674997689c36f"}
I edited the log to hide my url.
Request:
POST /browser/3799c094da/cool.html?WOPISrc=https%3A%2F%2Fmonsoon.my-site.org%3A5021%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F567_occmiu611x0t&title=%2FNew%20document.odt&lang=en&closebutton=1&revisionhistory=1 HTTP/1.1
Host: monsoonmy-site.org
User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:132.0) Gecko/20100101 Firefox/132.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate, br, zstd
Content-Type: application/x-www-form-urlencoded
Content-Length: 4348
Origin: null
Connection: keep-alive
Cookie: nc_sameSiteCookielax=true; nc_sameSiteCookiestrict=true; __Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; occmiu611x0t=ecebbb737a6c5aa294173b9188848427; oc_sessionPassphrase=wWDd6l8H%2Fa2tMvjGeIVIwtpg7RcQnqMSRX395vo43mnmJqurY4d8%2FCvU5GV09zzugvFoM1AtaoWOOxKnUMMJfUvEsOY1Q%2FhQXWU19GcL4AiuF6RzHF9Wqa8UasvuX%2F6j; nc_username=admin; nc_token=YPyXL7hLyYC2X8ULniIBsuK17vh0h8Yl; nc_session_id=ecebbb737a6c5aa294173b9188848427
Upgrade-Insecure-Requests: 1
Sec-Fetch-Dest: iframe
Sec-Fetch-Mode: navigate
Sec-Fetch-Site: same-site
Sec-Fetch-User: ?1
Priority: u=4
Response:
HTTP/1.1 404 Not Found
Server: nginx/1.18.0 (Ubuntu)
Date: Fri, 29 Nov 2024 10:31:40 GMT
Content-Type: text/html
Transfer-Encoding: chunked
Content-Encoding: gzip
[ N 2024-11-29 10:16:58.9382 153218/T1 age/Wat/WatchdogMain.cpp:1370 ]: Starting Passenger watchdog...
[ N 2024-11-29 10:16:58.9667 153222/T1 age/Cor/CoreMain.cpp:1341 ]: Starting Passenger core...
[ N 2024-11-29 10:16:58.9683 153222/T1 age/Cor/CoreMain.cpp:257 ]: Passenger core running in multi-application mode.
[ N 2024-11-29 10:16:58.9861 153222/T1 age/Cor/CoreMain.cpp:1016 ]: Passenger core online, PID 153222
[ N 2024-11-29 10:17:01.1207 153222/T6 age/Cor/SecurityUpdateChecker.h:519 ]: Security update check: no update found (next check in 24 hours)
(redmine is running on another port)
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'will hide',
'passwordsalt' => 'will hide',
'secret' => 'will hide',
0 => 'monsoon.my-site.org',
1 => 'monsoon.my-site.org:5021',
'dbtype' => 'sqlite3',
'version' => '30.0.2.2',
'overwrite.cli.url' => 'http://monsoon.my-site.org:5021',
'overwritehost' => 'monsoon.my-site.org:5021',
'app_install_overwrite' =>
0 => 'files_mindmap',
1 => 'inventory',
2 => 'files_3d',
Please help
Thank you.
