I want to use two different nextcloud-php-fpm-containers behind a nginx-webserver.
What is the way to do it?
The documentroot directories in the nginx-container change eg.
instance 1: nextcloud1: / var / www / html / nextcloud1
instance 2: nextcloud2: / var / www / html / nextcloud2
Unfortunately, I can not find any instructions on how to make the Nginx configuration look if the root directory of fpm-php and nginx-server is different.
I appreciate all the hints for solving using the original nextcloud: fpm containers
i would put traefik.io in front of the nginx server. like in https://github.com/ReinerNippes/nextcloud_on_docker/blob/master/roles/docker_container/tasks/traefik.yml
in case you donβt want to use traefik i guess you have to put
volume:
- nextcloud1:/var/www/html
- nextcloud-data1:/var/nc-data
and
volume:
- nextcloud2:/var/www/html
- nextcloud-data2:/var/nc-data
in the nextcloud and nginx docker config.
thx. for your answer. I found the solution:
in the part of fastcgi:
β¦
fastcgi_intercept_errors on;
root /var/www/html;
you can put the parameter of the root-directory in the php-fpm instances.
