Docker-compose - almost perfect, need help with collabora/code
Hi everbody! :smile:
I am learning and trying to build an optimized docker-compose.yml to run Nextcloud with Collabora Online.
First, I want to get a fully funcional Nextcloud on my VPS using plain HTTP.
After everything is working right and hopefully, optimized, I will try to put this setup behind a docker container running Caddy (for HTTPS and certificates management).
I wrote the docker-compose.yml with two choices for database, Postgres or Mariadb. But discovered that Postgres container takes more time to be ready and Nextcloud installation (using environment variables) fails. With Mariadb install fails at first (you can see in logs) but retries and finalizes the installation.
Everything going well until I tried to “attach” Collabora Online container. I don’t know what is wrong, if is something only on Collabora container, other(s) conteiner(s) configuration or something to be done on Nextcloud settings (as admin).
Configuration on Settings / Nextcloud Office appears to be ok: I got the green circle on “Setting up a new server” after click “Use your own server”, fill the URL (using user:password, as I saw elsewhere) and then checking “Disable certificate verification (insecure)”.
http://user:password@collabora.example.com:9980
When I try to create a new document, Nextcloud let me choose a template, I click “Create” and then “Loading test.odt…” until “Document loading failed” - “Failed to load Nextcloud Office - please try again later”. The only option is to click on a close button that leads back to Nextcloud showing the “test.odt” document on the list of files.
Bellow, docker-compose.yml
version: '2'
services:
  #nextcloud-db:
  #  image: postgres:12-alpine
  #  container_name: nextcloud-db
  #  restart: unless-stopped
  #  environment:
  #    POSTGRES_USER: nextcloud
  #    POSTGRES_PASSWORD: password
  #  volumes:
  #    - nextcloud-db:/var/lib/postgresql/data
  #    - /etc/localtime:/etc/localtime:ro
  nextcloud-db:
    image: mariadb
    environment:
      MYSQL_ROOT_PASSWORD: password
      MYSQL_PASSWORD: password
      MYSQL_DATABASE: nextcloud
      MYSQL_USER: nextcloud
    volumes:
      - nextcloud-db:/var/lib/mysql
  nextcloud-cache:
    image: redis:alpine
    container_name: nextcloud-cache
    mem_limit: 2048m
    mem_reservation: 512m
    command: redis-server --requirepass password
  nextcloud-app:
    image: nextcloud:fpm-alpine
    container_name: nextcloud-app
    depends_on:
      - nextcloud-db
      - nextcloud-cache
    environment:
      MYSQL_HOST: nextcloud-db
      POSTGRES_DB: nextcloud
      POSTGRES_HOST: nextcloud-db
      NEXTCLOUD_ADMIN_USER: admin
      NEXTCLOUD_ADMIN_PASSWORD: password
      NEXTCLOUD_TRUSTED_DOMAINS: nextcloud.example.com collabra.example.com
      REDIS_HOST: nextcloud-cache
      REDIS_HOST_PASSWORD: password
      SMTP_HOST: mail.example.com
      SMTP_SECURE: tls
      SMTP_PORT: 587
      SMTP_AUTHTYPE: LOGIN
      SMTP_NAME: mailer@example.com
      SMTP_PASSWORD: password
      MAIL_FROM_ADDRESS: no-reply
      MAIL_DOMAIN: example.com
    volumes:
      - nextcloud-app:/var/www/html
  nextcloud-web:
    image: nginx:alpine
    container_name: nextcloud-web
    ports:
      - 80:80
    volumes:
      - ./nginx.conf:/etc/nginx/nginx.conf:ro
    volumes_from:
      - nextcloud-app
  nextcloud-collabora:
    image: collabora/code
    container_name: nextcloud-collabora
    ports:
      - 9980:9980
    depends_on:
      - nextcloud-web
    cap_add:
     - MKNOD
    environment:
      - username=admin
      - password=password
      - DONT_GEN_SSL_CERT=yes
      - server_name=collabra.example.com
      - dictionaries=en_US es_ES pt_BR
      - extra_params=--o:ssl.enable=false
      # Domain the service should be accessed from:
     #- domain=${VIRTUAL_HOST}
     #- domain=example.com
     #- VIRTUAL_HOST=${COLLABORA_VIRTUAL_HOST}
     #- VIRTUAL_HOST=collabra.example.com
     #- LETSENCRYPT_HOST=${COLLABORA_VIRTUAL_HOST}
      # Extra parameters to Collabora, see also
      # https://www.collaboraoffice.com/code/nginx-reverse-proxy/:
      # SSL terminates at the proxy
     #- extra_params=--o:ssl.enable=false --o:ssl.termination=true
    volumes:
volumes:
  nextcloud-app:
  nextcloud-db:
networks:
  default:
    external: true
and nginx.conf
worker_processes auto;
error_log  /var/log/nginx/error.log warn;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
    include       /etc/nginx/mime.types;
    default_type  application/octet-stream;
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    # Prevent nginx HTTP Server Detection
    server_tokens   off;
    keepalive_timeout  65;
    #gzip  on;
    upstream php-handler {
        server nextcloud-app:9000;
    server {
        listen 80;
        # HSTS settings
        # could take several months.
        #add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
        # set max upload size
        client_max_body_size 512M;
        fastcgi_buffers 64 4K;
        gzip on;
        gzip_vary on;
        gzip_comp_level 4;
        gzip_min_length 256;
        gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
        # Pagespeed is not supported by Nextcloud, so if your server is built
        # with the `ngx_pagespeed` module, uncomment this line to disable it.
        #pagespeed off;
        # HTTP response headers borrowed from Nextcloud `.htaccess`
        add_header Referrer-Policy                      "no-referrer"   always;
        add_header X-Content-Type-Options               "nosniff"       always;
        add_header X-Download-Options                   "noopen"        always;
        add_header X-Frame-Options                      "SAMEORIGIN"    always;
        add_header X-Permitted-Cross-Domain-Policies    "none"          always;
        add_header X-Robots-Tag                         "none"          always;
        add_header X-XSS-Protection                     "1; mode=block" always;
        # Remove X-Powered-By, which is an information leak
        root /var/www/html;
        # Specify how to handle directories -- specifying `/index.php$request_uri`
        # here as the fallback means that Nginx always exhibits the desired behaviour
        # when a client requests a path that corresponds to a directory that exists
        # on the server. In particular, if that directory contains an index.php file,
        # that file is correctly served; if it doesn't, then the request is passed to
        # the front-end controller. This consistent behaviour means that we don't need
        # to specify custom rules for certain paths (e.g. images and other assets,
        # `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
        # `try_files $uri $uri/ /index.php$request_uri`
        # always provides the desired behaviour.
        index index.php index.html /index.php$request_uri;
        # Rule borrowed from `.htaccess` to handle Microsoft DAV clients
        location = / {
            if ( $http_user_agent ~ ^DavClnt ) {
                return 302 /remote.php/webdav/$is_args$args;
        location = /robots.txt {
            allow all;
            log_not_found off;
            access_log off;
        # Make a regex exception for `/.well-known` so that clients can still
        # access it despite the existence of the regex rule
        # `location ~ /(\.|autotest|...)` which would otherwise handle requests
        # for `/.well-known`.
        location ^~ /.well-known {
            # The rules in this block are an adaptation of the rules
            # in `.htaccess` that concern `/.well-known`.
            location = /.well-known/carddav { return 301 /remote.php/dav/; }
            location = /.well-known/caldav  { return 301 /remote.php/dav/; }
            location /.well-known/acme-challenge    { try_files $uri $uri/ =404; }
            location /.well-known/pki-validation    { try_files $uri $uri/ =404; }
            # Let Nextcloud's API for `/.well-known` URIs handle all other
            # requests by passing them to the front-end controller.
            return 301 /index.php$request_uri;
        # Rules borrowed from `.htaccess` to hide certain paths from clients
        location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/)  { return 404; }
        location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console)                { return 404; }
        # Ensure this block, which passes PHP files to the PHP process, is above the blocks
        # which handle static assets (as seen below). If this block is not declared first,
        # then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
        # to the URI, resulting in a HTTP 500 error response.
        location ~ \.php(?:$|/) {
            # Required for legacy support
            rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy) /index.php$request_uri;
            set $path_info $fastcgi_path_info;
            include fastcgi_params;
            fastcgi_param PATH_INFO $path_info;
            #fastcgi_param HTTPS on;
            fastcgi_param modHeadersAvailable true;         # Avoid sending the security headers twice
            fastcgi_param front_controller_active true;     # Enable pretty urls
            fastcgi_pass php-handler;
            fastcgi_intercept_errors on;
        location ~ \.(?:css|js|svg|gif)$ {
            expires 6M;         # Cache-Control policy borrowed from `.htaccess`
            access_log off;     # Optional: Don't log access to assets
        location ~ \.woff2?$ {
            expires 7d;         # Cache-Control policy borrowed from `.htaccess`
        location /remote {
            return 301 /remote.php$request_uri;
        location / {
            try_files $uri $uri/ /index.php$request_uri;
So, “let’s get ready to rumble”! :crazy_face:
Update: I discovered that the problem with Postgres were my fault!
After uncomment “nextcloud-db” section for Postgres and comment “nextcloud-db” section for Mariadb I forgot to also comment the environment variables “MYSQL_*”.
Apparently they take precedence over “POSTGRES_*” environment variables and Nextcloud try to connect to a MySQL host instead of the Postgres host.
  nextcloud-app:
    environment:
      #MYSQL_DATABASE: nextcloud     <- comment these
      #MYSQL_USER: nextcloud         <- lines if
      #MYSQL_PASSWORD: password      <- you choose
      #MYSQL_HOST: nextcloud-db      <- Postgres as DB
Cool, did you sort out your compose script?
Not yet.
I saw that “Nextcloud All-in-One” and I am also trying make it work behind Caddy. No success until now.
Reverse-proxy (Caddy) already in place. How install/configure NC AIO?
