Docker based NextCloud AiO with nginx on separate Ubuntu VM - not working
Hi!
Recently I’m struggling to run Docker based Nextcloud 30 with nginx.
I use for that 2 Ubuntu 24.10 VMs (also tried on 24.04). They are fresh installs, run in the same subnet with almost no local FWs (Nextcloud AiO doesn’t deploy if you flush iptables before). I can’t assign public IP to any of them, so I do port 80 & 443 translation towards Nginx VM.
The network settings
  • Mikrotik ISP home GW
[admin@RB4011.home] > ip firewall nat print
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix=“” ipsec-policy=out,none
1 chain=dstnat action=dst-nat to-addresses=192.168.1.52 to-ports=443 protocol=tcp in-interface=pppoe-out1 dst-port=443 log=no log-prefix=“”
2 chain=dstnat action=dst-nat to-addresses=192.168.1.52 protocol=tcp in-interface=pppoe-out1 dst-port=80 log=no log-prefix=“”
  • VM with nginx has address: 192.168.1.52/24, local FW settings:
shadow@Ubuntu-24:~$ sudo ufw status
Status: inactive
shadow@Ubuntu-24:~$ sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
  • Element listy
VM with NC has address: 192.168.1.47/24, local FW settings after NC install:
shadow@Ubuntu-24:~/docker/nextcloud$ sudo ufw status
Status: inactive
shadow@Ubuntu-24:~/docker/nextcloud$ sudo iptables -L
Chain FORWARD (policy DROP)
DOCKER-USER all – anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all – anywhere anywhere
ACCEPT all – anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all – anywhere anywhere
Chain DOCKER (2 references)
ACCEPT tcp – anywhere 172.17.0.2 tcp dpt:http-alt
ACCEPT tcp – anywhere 172.18.0.6 tcp dpt:11000
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all – anywhere anywhere
RETURN all – anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
DROP all – anywhere anywhere
Chain DOCKER-USER (1 references)
The NC config
I followed the manuals for NextCloud AiO, I took suggesterd compose file from compose.yaml and I removed the 80 and 8443 ports from there. I uncommented the proxy related lines (APACHE_PORT, APACHE_IP_BINDIGNG) I setup my own datadir (I tried also without this setting). Due to no option to assign public IP to any VM (these are Vmware ESXi 8 based VMs in my home LAN) I skip the domain check SKIP_DOMAIN_VALIDATION: true.
Below is my full docker-compose.yml (with deleted commented lines for convenience):
services:
init: true
restart: unless-stopped
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro # May be changed on macOS, Windows or docker rootless. See the applicable documentation. If adjusting, don’t forget to also set ‘WATCHTOWER_DOCKER_SOCKET_PATH’!
network_mode: bridge # add to the same network as docker run would do
ports:
- 8080:8080
APACHE_PORT: 11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
APACHE_IP_BINDING: 127.0.0.1 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else) that is running on the same host. See reverse-proxy.md
NEXTCLOUD_DATADIR: /home/shadow/docker/nextcloud/appdata # Allows to set the host directory for Nextcloud’s datadir. :warning::warning::warning: Warning: do not set or adjust this value after the initial Nextcloud installation is done! See how-to-change-the-default-location-of-nextclouds-datadir
how-to-add-php-extensions-permanently-to-the-nextcloud-container
volumes: # If you want to store the data on a different drive, see how-to-store-the-filesinstallation-on-a-separate-drive
The nginx config
Firstly I installed nginx and certbot and created certs for my website. Next I followed the reverse-proxy.md focusing on section Nginx, Freenginx, Openresty.
Below my /etc/nginx/sites-available/default file:
shadow@Ubuntu-24:/etc/nginx/sites-available$ cat default
map $http_upgrade $connection_upgrade {
default upgrade;
‘’ close;
server {
listen 80;
listen [::]:80; # comment to disable IPv6
if ($scheme = "http") {
# listen 443 ssl http2;      # for nginx versions below v1.25.1
# listen [::]:443 ssl http2; # for nginx versions below v1.25.1 - comment to disable IPv6
listen 443 ssl;      # for nginx v1.25.1+
# listen [::]:443 ssl; # for nginx v1.25.1+ - keep comment to disable IPv6
# http2 on;                                 # uncomment to enable HTTP/2        - supported on nginx v1.25.1+
# http3 on;                                 # uncomment to enable HTTP/3 / QUIC - supported on nginx v1.25.0+
# quic_retry on;                            # uncomment to enable HTTP/3 / QUIC - supported on nginx v1.25.0+
# add_header Alt-Svc 'h3=":443"; ma=86400'; # uncomment to enable HTTP/3 / QUIC - supported on nginx v1.25.0+
# listen 443 quic reuseport;       # uncomment to enable HTTP/3 / QUIC - supported on nginx v1.25.0+ - please remove "reuseport" if there is already another quic listener on port 443 with enabled reuseport
# listen [::]:443 quic reuseport;  # uncomment to enable HTTP/3 / QUIC - supported on nginx v1.25.0+ - please remove "reuseport" if there is already another quic listener on port 443 with enabled reuseport - keep comment to disable IPv6
server_name drive.shadow.com;
location / {
    proxy_pass http://192.168.1.47:11000$request_uri;
    proxy_set_header X-Forwarded-Port $server_port;
    proxy_set_header X-Forwarded-Scheme $scheme;
    proxy_set_header Host $host;
    proxy_request_buffering off;
    proxy_read_timeout 86400s;
    client_max_body_size 0;
    # Websocket
    proxy_http_version 1.1;
    proxy_set_header Connection $connection_upgrade;
# If running nginx on a subdomain (eg. nextcloud.example.com) of a domain that already has an wildcard ssl certificate from certbot on this machine,
# the <your-nc-domain> in the below lines should be replaced with just the domain (eg. example.com), not the subdomain.
# In this case the subdomain should already be secured without additional actions
ssl_certificate /etc/letsencrypt/live/drive.shadow.com/fullchain.pem;   # managed by certbot on host machine
ssl_certificate_key /etc/letsencrypt/live/drive.shadow.com/privkey.pem; # managed by certbot on host machine
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305;
ssl_prefer_server_ciphers on;
# Optional settings:
# OCSP stapling
# ssl_stapling on;
# ssl_stapling_verify on;
# ssl_trusted_certificate /etc/letsencrypt/live/<your-nc-domain>/chain.pem;
# replace with the IP address of your resolver
# resolver 127.0.0.1; # needed for oscp stapling: e.g. use 94.140.15.15 for adguard / 1.1.1.1 for cloudflared or 8.8.8.8 for google - you can use the same nameserver as listed in your /etc/resolv.conf file
The NC behavior
After enabling the proxy and installing NC 30 via initial setup
on localhost port 8080/setup I cannot reach the website - from NC VM nor from nginx VM, using the outside address I’m getting “ERR_CONNECTION_REFUSED”.
From outside world I’m getting nginx 502 Bad Gateway
I took a look using Wireshark and I see that traffic to nginx VM is correct
https://i.imgur.com/4iouKiE.png
But next session is actively reset by NC VM:
https://i.imgur.com/lWBkFvG.png
I see that NC VM is listening on APACHE_PORT
shadow@Ubuntu-24:~/docker/nextcloud$ sudo netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 1150/systemd-resolv
tcp 0 0 127.0.0.54:53 0.0.0.0:* LISTEN 1150/systemd-resolv
tcp 0 0 127.0.0.1:11000 0.0.0.0:* LISTEN 2596/docker-proxy
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 2546/docker-proxy
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 1839/cupsd
tcp6 0 0 ::1:631 :::* LISTEN 1839/cupsd
tcp6 0 0 :::8080 :::* LISTEN 2552/docker-proxy
udp 0 0 192.168.1.47:58415 0.0.0.0:* 2963/chrome-remote-
udp 0 0 172.17.0.1:33970 0.0.0.0:* 2963/chrome-remote-
udp 0 0 172.17.0.1:42595 0.0.0.0:* 2963/chrome-remote-
udp 0 0 0.0.0.0:51603 0.0.0.0:* 1307/avahi-daemon:
udp 0 0 172.18.0.1:44926 0.0.0.0:* 2963/chrome-remote-
udp 0 0 192.168.1.47:37935 0.0.0.0:* 2963/chrome-remote-
udp 0 0 0.0.0.0:5353 0.0.0.0:* 1307/avahi-daemon:
udp 0 0 172.17.0.1:46379 0.0.0.0:* 2963/chrome-remote-
udp 0 0 172.18.0.1:39047 0.0.0.0:* 2963/chrome-remote-
udp 0 0 192.168.1.47:49141 0.0.0.0:* 2963/chrome-remote-
udp 0 0 127.0.0.54:53 0.0.0.0:* 1150/systemd-resolv
udp 0 0 127.0.0.53:53 0.0.0.0:* 1150/systemd-resolv
udp 0 0 172.18.0.1:49531 0.0.0.0:* 2963/chrome-remote-
udp6 0 0 :::33926 :::* 1307/avahi-daemon:
udp6 0 0 :::5353 :::* 1307/avahi-daemon:
But connections to that port are being refused:
shadow@Ubuntu-24:~/docker/nextcloud$ telnet 192.168.1.47 11000
Trying 192.168.1.47…
telnet: Unable to connect to remote host: Connection refused
shadow@Ubuntu-24:~/docker/nextcloud$ curl http://192.168.1.47:11000
curl: (7) Failed to connect to 192.168.1.47 port 11000 after 0 ms: Could not connect to server
I also see that nc aio apache container is having some issues every time few minutes after starting it up:
shadow@Ubuntu-24:~/docker/nextcloud$ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
aea2ea0c8075 nextcloud/aio-apache:latest “/start.sh /usr/bin/…” 9 hours ago Up 52 minutes (unhealthy) 80/tcp, 127.0.0.1:11000->11000/tcp nextcloud-aio-apache
31187fe951a9 nextcloud/aio-notify-push:latest “/start.sh” 9 hours ago Up 52 minutes (healthy) nextcloud-aio-notify-push
ee2b7831a460 nextcloud/aio-nextcloud:latest “/start.sh /usr/bin/…” 9 hours ago Up 52 minutes (healthy) 9000/tcp nextcloud-aio-nextcloud
16fb658421b4 nextcloud/aio-redis:latest “/start.sh” 9 hours ago Up 52 minutes (healthy) 6379/tcp nextcloud-aio-redis
4a41ec9907de nextcloud/aio-postgresql:latest “/start.sh” 9 hours ago Up 52 minutes (healthy) 5432/tcp nextcloud-aio-database
4d575a2c6ff9 nextcloud/all-in-one:latest “/start.sh” 9 hours ago Up 52 minutes (healthy) 80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp nextcloud-aio-mastercontainer
After checking netstat on that apache container it seems like it listens on IPv6 only:
aea2ea0c8075:/usr/local/apache2$ netstat -tulpn
netstat: showing only processes with your user ID
tcp 0 0 127.0.0.1:2019 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.11:35469 0.0.0.0:* LISTEN -
tcp 0 0 :::8000 :::* LISTEN 42/httpd
tcp 0 0 :::11000 :::* LISTEN -
udp 0 0 127.0.0.11:40073 0.0.0.0:*
I’m not sure what to do next in order to make it run. I already tried to deploy this multiple times (struggling for a week already). I managed to run docker based nextcloud (not AiO) using nginx on the same VM, but I need this on 2 separate VMs, cause I have to use Sophos FW as proxy in near future.
Any hints?
Hi, can you follow all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub?
Greetings,
I currently have a setup running Nextcloud AIO on a VM (VM02) with Ubuntu Server 24.04 under Proxmox. Additionally, I have an NGINX Proxy server running on a separate VM (VM01). The subdomain routing is configured to pass traffic from the NGINX Proxy to the Nextcloud AIO instance.
I’m not sure if this setup fits your needs, but I’m happy to share more details if you’re interested. I can provide:
  • My docker-compose.yml configuration
  • Screenshots of the NGINX Proxy server settings
Let me know if you’d like me to share this information or if you have any questions.
Sure - any hints are good for me. Especially “known working examples”
From what I see that is bad is:
NC Apache container:
  • has status: unhealthy
  • seems listening only on IPv6 apache port 11000
  • Actively refuses connections to apache port 11000
Docker has network scheme that by default they are private to the containers and the host that they run on, but I think (maybe I’m wrong) - this config should expose communication to port 11000
volumes:
services:
 nextcloud:
   volumes:
   ports:
     - 6789:8080 # change the port on the left side if it's already in use on your host system.
   environment:
     - APACHE_PORT=11000
Then Nextcloud AIO for a local start is available on http://lanip-of-your-vm02:6789. You can choose which containers to run.
Start all your Nextcloud AIO dockers there.
Then you can set up NGINX Proxy server for domain/subdomain forwarding.
My NGINX Proxy settings
3 pages of settings -
nginx_settings.pdf (133,0 KB)
When you will set up SSL tab the first time - use Request new certificate.
Code for Advanced tab:
client_body_buffer_size 512k;
Let me know if it will help you.
Yes because you’ve set APACHE_IP_BINDING: 127.0.0.1. This cannot work. See step 3 here: all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
Thanks - I’ll review this after work and give it a try :slight_smile:
I reviewed my setup and it’s almost 100% the same as yours.
I just enabled HTTP 2 and added “client_body_buffer_size 512k;”.
Unfortunately this changed nothing.
My attempts always finish with such suspected guys:
  1. Apache container spins up but it’s unhealthy
root@Ubuntu-24:/home/shadow82# docker ps
aea2ea0c8075 nextcloud/aio-apache:latest “/start.sh /usr/bin/…” 23 hours ago Up 14 hours (unhealthy) 80/tcp, 127.0.0.1:11000->11000/tcp nextcloud-aio-apache
31187fe951a9 nextcloud/aio-notify-push:latest “/start.sh” 23 hours ago Up 14 hours (healthy) nextcloud-aio-notify-push
ee2b7831a460 nextcloud/aio-nextcloud:latest “/start.sh /usr/bin/…” 23 hours ago Up 14 hours (healthy) 9000/tcp nextcloud-aio-nextcloud
16fb658421b4 nextcloud/aio-redis:latest “/start.sh” 23 hours ago Up 14 hours (healthy) 6379/tcp nextcloud-aio-redis
4a41ec9907de nextcloud/aio-postgresql:latest “/start.sh” 23 hours ago Up 14 hours (healthy) 5432/tcp nextcloud-aio-database
4d575a2c6ff9 nextcloud/all-in-one:latest “/start.sh” 23 hours ago Up 14 hours (healthy) 80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp nextcloud-aio-mastercontainer
  1. When logged into that apache I see it listens on IPv6 port 11000 only (why no IPv4?)
root@Ubuntu-24:/home/shadow82# docker exec -it aea2ea0c8075 bash
udp 0 0 127.0.0.11:40073 0.0.0.0:* -
  1. Connections from any machine to the one with NC on port 11000 are always actively refused
shadow82@Ubuntu-24:/etc/nginx/sites-available$ telnet 192.168.1.47 11000
(I observe same things when trying curl or wireshark dump)
Maybe some docker network settings?
Does this nextcloud-aio docker network looks good or is it “too local” maybe?
root@Ubuntu-24:/home/shadow82# docker network ls
NETWORK ID NAME DRIVER SCOPE
bd1b6b416f4d bridge bridge local
70b4246cde07 host host local
2a48ec8281cc nextcloud-aio bridge local
fe3a93d59856 none null local
I use IPv4 not IPv6.
What about firewall?
Me too. I didn’t set any IPv6 in this setup. Even nginx is listening on IPv4 only
About FWs - these are 2 VMs running in a single subnet with local FWs disabled
VM with nginx:
shadow82@Ubuntu-24:/$ sudo ufw status
Status: inactive
shadow82@Ubuntu-24:/$ sudo iptables -L
VM with NC
root@Ubuntu-24:/home/shadow82# ufw status
Status: inactive
root@Ubuntu-24:/home/shadow82# iptables -L
DefGW FW allows porets 80 and 443 from the outside world
If you try https://lanip-of-nextcloud:port (not 11000)
  • I mean the port that you have in your docker-compose.yml file… in my case 6789.
   ports:
Can you access to local AIO instance?
I am sending mine -
local-access_converted.pdf (90,3 KB)
Quite the same result on my VM with NC:
https://i.imgur.com/0GJWXQ1.png
But after clicking “open your nextcloud” I’m getting nginx 502 error
https://i.imgur.com/WmeDXua.png
My docker compose interesting part:
ports:
  - 8080:8080
  # AIO_DISABLE_BACKUP_SECTION: false # Setting this to true allows to hide the backup section in the AIO interface. S>
  APACHE_PORT: 11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudfl>
  APACHE_IP_BINDING: 127.0.0.1 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx, >
My nginx default config file:
default upgrade;
‘’ close;
server {
listen 80;
location / {
    # Websocket
So only initial setup website shows up - not the desired NC WebGUI
I’m sorry, I don’t have any more ideas.
I used this tutorial for my AIO instance. Maybe there are some steps you can follow.
Thanks - I’ll go through it for sure! :slight_smile:
This video might also be useful:
