I am trying to set up Nextcloud AIO Docker container on my local computer running Debian. I am exposing it using Cloudflare Tunnel and Nginx reverse proxy.
I thought I finally configured everything correctly. My compose file looks like this:
nginx
image: nginx:latest
container_name: nginx
restart: unless-stopped
networks:
- media_network
volumes:
- ./nginx/conf.d:/etc/nginx/conf.d:ro
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: always
ports:
- 8080:8080 # AIO management interface (use only locally)
environment:
- APACHE_PORT=11000
- APACHE_IP_BINDING=0.0.0.0
- APACHE_ADDITIONAL_NETWORK=media_network
- TZ=Europe/Prague
- SKIP_DOMAIN_VALIDATION=true # Needed because you use Cloudflare tunnel!
- NEXTCLOUD_DATADIR=/mnt/nextcloud/data
volumes:
- /mnt/primary/nextcloud/data:/mnt/nextcloud/data
networks:
- media_network
volumes:
But it doesn’t run the setup screen and the logs look like this:
docker logs nextcloud-aio-mastercontainer | head
Trying to fix docker.sock permissions internally...
WARNING: No memory limit support
Creating docker group internally with id 124
WARNING: No swap limit support
It seems like you did not give the mastercontainer volume the correct name? (The 'nextcloud_aio_mastercontainer' volume was not found.)
Using a different name is not supported since the built-in backup solution will not work in that case!
Does anybody know, what am I doing wrong?
Thank you very much for help
