I have Nextant set up and working properly so far. However, it appears that it also indexes trash files, which is a problem for me, since I have applications which overwrite files very often, resulting in hundreds of useless search results.
Is there any way to disable indexing of user’s trash bins? I know that for normal directories, I can just add a .noindex file, but how does that apply for the Trash Bin? Would I need to go into the filesystem and add the .noindex file into …/username/files_trashbin manually?
