Trying to get my system back up every time I try to use lets encrypt I get this?
Please deploy a DNS TXT record under the name:
_acme-challenge.(MYSITENAME).
with the following value:
F1sd-hzUKFfYlfG7NxWZFMFj21hcFDzeityQOKq_W4w
Before continuing, verify the TXT record has been deployed. Depending on the DNS
provider, this may take some time, from a few seconds to multiple minutes. You can
check if it has finished deploying with aid of online tools, such as the Google
Admin Toolbox: https://toolbox.googleapps.com/apps/dig/#TXT/_acme-challenge.triplesalarm.dedyn.io.
Look for one or more bolded line(s) below the line ‘;ANSWER’. It should show the
value(s) you’ve just added.
