Discord Integration for notifications - flow, webhooks, activity
Hi not sure where to put this:
I want to be able to send notifications to my Discord Channel when someone Downloads a file or files. I cant find anything to do this. Please help this would be greatly helpful and appreciated
Could be done with an rss bot and the activity app.
Or, could be possible with the webhooks app.
You’d have to figure out how to filter the results from the activity feed to only show what you want.
Since i have no experience in writing code or values …as i think the webhook app would work… ive tried what i know and even did flows. nothing lol you would think nextcloud would have this integration app but maybe imi wrong
Webhooks apps has been developed by a 3rd party.
It integrates into Flow as you know, but that needs an additional app
You can use this to write custom scripts to respond to the sorts of events you have described. Not sure how to write such a script, but this is where you would figure that out.
I looked into this general topic more and have more info. Bear with me:
Available Webhook events - copypasta of types supported when you click me
Available events
Calendar Object Created
Fires whenever a calendar event is created.
Config name: webhooks_calendar_object_created_url
Calendar Object Updated
Fires whenever a calendar event is edited (including meeting participant accepting/declining invitations).
Config name: webhooks_calendar_object_updated_url
Calendar Object Moved to Trash
Fires whenever a calendar event is soft-deleted (moved to trash).
Config name: webhooks_calendar_object_moved_to_trash_url
Calendar Object Deleted
Fires whenever a calendar event is permanently deleted (i.e. deleted from the trashbin).
Config name: webhooks_calendar_object_deleted
Login Failed
Fires whenever a login attempt with an existing username fails.
Config name: webhooks_login_failed_url
Password Updated
Fires whenever user’s password is changed.
Config name: webhooks_password_updated_url
Share Created
Fires whenever a new share is created.
Config name: webhooks_share_created_url
User Changed
Fires whenever a user account is edited. Includes values before and after edit.
Config name: webhooks_user_changed_url
User Created
Fires whenever a new user is created.
Config name: webhooks_user_created_url
User Deleted
Fires whenever a user account is deleted.
Config name: webhooks_user_deleted_url
User Live Status Updated
Fires whenever user’s live status is updated to online (happens when user navigates between apps and doesn’t necessarily indicate that the status changed).
Config name: webhooks_user_status_url
User Logged In
Fires whenever a user logs in successfully.
Config name: webhooks_user_logged_in_url
User Logged Out
Fires whenever a user logs out successfully.
Config name: webhooks_user_logged_out_url
Flow events
  • File created
  • File updated
  • File renamed
  • File copied
  • File deleted
  • Tag assigned
As far as sending the notification on a file upload or change, seems that is being done with external script support in flow…
curl -d @%f http://your.awesome.api/uploadfile
Or something like this.
Unfortunately required in this case. Here is a request on improving Webhooks configuration from the webui.
If you want to try this method you’ll need to install the download shared activity app and then apply your own filtering to the rss feed from activity.
See https://github.com/nextcloud/activity/issues/45
and RSS feed for Shared activity · Issue #464 · nextcloud/activity · GitHub
Thank you for replying ! i will check into all this. The RSS feed would have worked if the Activity settings button worked. jsut click and nothing. cant enable RSS. but i will definitely look at all of this :slight_smile:
I thought of a way you could do this…
  • Create a fake user with a name like “DIspatch”
  • Confirm “Dispatch” will automatically accept whatever group or others shares you send to it without needing any additional confirmation, so you won’t need to login.
  • Installed shared download activities app
  • Enable RSS in activity app for “Dispatch”
  • Configure activity app in user settings to only relay shared download activities
  • Share RSS feed to your Discord using whatever RSS bot on that end.
Profit. Dispatch’s activity rss will now be relayed to your Discord room.
Main issue with this approach is it is not really scabable beyond one room per user created. :slight_smile:
If you want to scale the activities of one user across multiple rooms you can use FreshRSS or a similar 3rd party service to filter and re-share that RSS feed… but, that obviously requires more tooling.
