direct conection from smart phone to NextCloud server
Hello forum
In order to be able to make some tests with NextCloud from an Android smartphone I am wondering if there is a possibility to direct-connect the smartphone to the NextCloud box
withoput using cellular-data or WIFI, e.g. using an USB-connection.
Is such a direct connection possible? How
Thank you!
Joe
