example
longer
example
here
Nextcloud version (eg, 18.0.2): 19.01
Operating system and version (eg, Ubuntu 20.04): Linux, Version unknown (Webhosting)
Apache or nginx version (eg, Apache 2.4.25): unknown
PHP version (eg, 7.1): 7.3.20
Sometimes Users generate public links (german: Link teilen) of folders/data that shouldn’t be made publicaly available.
I can’t restrict the specific usergroup of generally creating links, because in certain cases it is needed.
But I can’t delete those public links without Impersonating the user who created the link.
Is there a way for admins to delete those links which I havent found so far, without impersonating?
Thx
