Default encryption module 2
This issue has ocurred in the past in a native installation and now on the snap as well. Searching for it reveals this issue has been around for years so if someone can find a permanent fix it would be appreciated.
Here is the issue:
Suddenly earlier today sync started failing for a user with the error " [Invalid private key for encryption app. Please update your private key password in your personal settings to recover access to your encrypted files"
Upon searching i found old threads with the issues such as at :Invalid private key for encryption app. Please update your private key password in your personal settings to recover access to your encrypted files
To temporarily fix the issue I had to follow the instructions by filder at Your private key password no longer matches your log-in password - #2 by privsec
But it raises the question, how safe is it to turn off the default encryption module? Are there alternative modules we can turn on to fix this?
Any idea?
anyone with any idea?
