Hi everybody,
I upgraded from NC12 to NC13 using the beta channel and web-interface. Everything was working nicely, until the redirection to the login which gives this error:
2018/02/06 12:01:54 [error] 12438#12438: *11
FastCGI sent in stderr: "PHP message: PHP Fatal error:
Declaration of OCA\FilesAccessControl\StorageWrapper::copyFromStorage(OCP\Files\Storage $sourceStorage, $sourceInternalPath, $targetInternalPath) must be compatible with OCP\Files\Storage::copyFromStorage(OCP\Files\Storage\IStorage $sourceStorage, $sourceInternalPath, $targetInternalPath) in /srv/www/nextcloud/apps/files_accesscontrol/lib/StorageWrapper.php on line 628"
while reading response header from upstream, client: 50.21.172.193, server: nextcloud.mydns.com, request: "GET / HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.0-fpm.sock:", host: "nextcloud.mydns.com"
I’m using Nginx. Any ideas?
